Here they are, they measure about 27” across but I have a 3” lift so that will make them a little longer and a little dimmer on the ground. The pictures were taken in my garage, I have garage door windows and a double window on the side of my garage so it’s pretty bright in there and they still show up nicely. It was about 1 minute per side, all you need is a small flathead screwdriver to pop them out, super easy.
Nice I didn’t think they would be that bright
congratulations they look great
Can you post some pictures at night. Also could you post a pic of how it looks with mirrors closed. Wondering if they would still look ok with mirrors folded in. Thanks
Still in the garage, headlights came on but otherwise no additional lighting. Obviously when the mirrors are closed they are worthless but since I rarely fold them it’s not an issue for me.
GMC brand is on back order
According to the email I got today
I order them right from the GMC website
Cant wait to see GMC, thanks everyone
I have to say I'm pleasantly surprised at how nice these OEM lights are. I have a 2017 Audi Q7 and the OEM puddle lights showing the Audi Rings were not as bright an they were mounted under the door.
How dark was it when that second picture was taken
Not that dark the sun was starting to come up. So not bright but not dark. Was surprised I could see it. But at night the light is very bright
I just installed during the day and couldn’t see the light now that the sun has set they look greatbd58f394816b95ee2172c73f7e2a5b03.jpg
Now the question is do I do the illuminated emblem
    • How did all that extra get added? AI bot!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
