2020 LT Z71 with the 5.3, ~3,900 miles purchased new approximately 2 months ago.
I washed the truck Saturday afternoon, let it sit over 24 hours, then went to start it Sunday night and got NOTHING.  That's when I noticed I had zero lights or sounds from the truck, and pressing the start/run button resulted in zero change.  No lights, sounds, door locks, or power anything.  I hooked up a fully charged battery and jumper cables to try and jump it, but the engine wouldn't even crank.  The lights and chimes worked, but nothing else.  I disconnected everything and now the truck is sitting in my driveway.  This is the second time this has happened to me with this truck and I'm not certain whats going on.  With a fresh battery connected via jumper cables, I checked to make sure I hadn't left any lights on or anything plugged in to the ports, but no lights were left on and no electronics were plugged in.  I have no clue what could cause the battery drain.
However I did notice one thing that might be of interest:  I usually press the door lock button twice on the FOB to make sure the truck is locked and the factory alarm is set,  but both mornings that I experienced a severe battery drain over night, I found my doors unlocked.  I am notorious for forgetting to lock my doors at least once or twice a month, so I wonder if by not locking my doors the PCM, Radio, or some other electronic is not shutting or cycling down?  Also, even with a fully charged battery, my doors will not automatically lock if I walk away from it so that again makes me wonder if the electronics are even shutting down when I forget to I lock the truck and set the factory alarm when walking away from it.
Irritating for sure, I'll be calling GM shortly.
Why are you locking the doors with your fob when they auto lock?
He said they don’t automatically lock.
Auto lock has to be applied in vehicle settings, the default is off.
Install some LEDs? Substitution of LEDs with improper resistance values for the stock halogens in the reverse lamps and directional/parking lamps can cause the perimeter lighting system controls and related systems to fail to sleep and even though lights are off the circuitry will continue to drain the battery.
They most certainly auto lock (cant speak for lower trims).
Its in the menu of the infotainment.
Well that’s all fine and dandy but he said HIS don’t. So that’s why he uses the button on the fob.
My door locks do not automatically lock though they are supposed to with my truck being an LT trim.  I have not checked the infotainment system options for auto locking doors so that might be something to check.
The truck is at the dealership right now and I'll post any information I receive.
Nothing installed other than aftermarket GM floor mats and a Du-Ha under seat storage bin.
if it were and older truck id say have the shop check the voltage regulator,  if it's faulty it might be giving enough power to run but not run and charge.  I havn't even found my alternator yet on this truck
They DO.  Just turn the feature on!
  The technician requested to hold the vehicle at the dealership over night for testing and found a bad cell on the battery.  They replaced the battery and I asked that they hold the vehicle for another overnight test just to make sure and they called this morning to let me know everything passed.  I won't be able to pick the truck up for a few days but hopefully the problem is solved.
Just dropped my 2020 GMC Sierra SLT off today at the dealer cuz my battery was dead the day after I took it home, 54 miles on truck... They too had me leave it over night for testing....
Must be somethun goin on they ain't tell'n me cuz they are keeping the truck all weekend, I'm hope it ain't serious.....
My brother had an F150 years ago that had perpetual battery drains.  Dealer couldn’t figure it out.
eventually, he actually tracked it down to a dash setting that literally created an open circuit and killed the battery.....   Ahhhh the fancy high tech gadgets ?
There is a TSB on this and it has to do with a short in a wire harness somewhere
Edited by ILSilverado
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
