2020 At4 tire pressure?
Just got my truck with the 20” wheels with the Goodyear trail blazer tires and door sticker is showing 32 psi front and 35 psi rear. Is this what everyone with this tire is running, 32/35? Dealer delivered it with 42 all around. Thx
Reduce them to 32/35.  They are over inflated at delivery.  Dealer never drops them.  They ride will be different with lower pressures.
I am running the door sticker pressures, and all is good!
7 minutes ago, JohnTz said:
If you had the 18 inch with the Wranglers the 42 would be correct.
They must just fill it to 42 as a std and not look at the door sticker. I lowered it to 35 all around just to keep track easier instead of the 32/35.
On 4/29/2020 at 7:52 PM, Pswa320 said:
Ok thanks. It was driving good where they had them but I lowered it to sticker numbers.
Door sticker is the pressures needed if the axles loads are at their max rated load.
If it's not loaded that heavy pressures can be less -- especially the rears, since an unloaded truck will weight less on the rear axle than the front.
yeah I understand that, was just scratching my head why the dealer had them 7-10 psi above the door sticker numbers on each tire. Stupid if you ask me.
    d.lowrey
    d.lowrey
  • Who's Online   3 Members, 0 Anonymous, 4,187 Guests (See full list)
