Hi all...I am looking to purchase a new LT TB with the midnight edition package. Most of the dealerships around me have been sold out but there is one dealership that has a black on black LT TB that is not the midnight edition. Does anyone know just what the difference in the LED headlights the TB has versus the regular LT TB. The dealership is telling me they can make this LT look just like the midnight edition which I understand you can just paint the bedliner, swap the bowties and black out the exhaust tips. I was just wondering if the headlights actually are much different. Any info would be appreciated. Thanks
What I’ve read the headlights are supposed to have black bezels that are different. Same LED technology and daytime running lights though. Here’s a pic of it but to be honest, I can’t tell the difference from this and the LED headlights that are on the LT TB. 3c8ceacf8d967176c8e3c33ff49a044f.jpg
From Chevy Press page:
Off-Road Focused Midnight Edition
The Silverado Midnight Edition is offered on the LT Trail Boss and Custom Trail Boss trims, including a 2-inch factory suspension lift and the Z71 Off Road Package with Rancho® mono-tube off-road shocks, an automatic locking rear differential, skid plates, 18-inch black painted wheels and Goodyear Duratrac off-road tires.
The Midnight Edition adds to Trail Boss’ look, but with an all-black approach: black Silverado badging, black grille, black Bowties, black bumpers, black exhaust tips and black off-road assist steps. The all-black appearance is accented by red recovery hooks.
The Custom Trail Boss Midnight Edition is available with either a 5.3L V-8 engine with six-speed automatic transmission or 6.2L V-8 engine with 10-speed automatic transmission. The LT Trail Boss Midnight Edition comes exclusively with 6.2L V-8 engine and 10-speed automatic transmission with 420 horsepower and 460 lb.-ft. of torque. The LT Trail Boss Midnight Edition also gets unique High-Intensity LED headlamps with dark bezels and full-curtain signature daytime running lamps.
The Silverado Midnight Edition is offered on the LT Trail Boss and Custom Trail Boss trims, including a 2-inch factory suspension lift and the Z71 Off Road Package with Rancho[emoji2400] mono-tube off-road shocks, an automatic locking rear differential, skid plates, 18-inch black painted wheels and Goodyear Duratrac off-road tires.
Maybe that’s why the DRL in that pic I sent is bigger. If you’re after the midnight look I would say wait until you get one at a dealer. Don’t have the dealer try to replicate it because they will probably just try to black out the badges and add the steps and say it’s the same.
I have a non-midnight black LT TB and these headlights look notably different. The headlights in the pic look like the headlights of HC trim (thicker DRL and LED turn signal).
There's no doofference at all in the headlights from the stock RST.  The blackout in the above photo is the normal surround of a black "wings" of a black grille and black body. Compare against the red surround in my photo. The LED lenses (and some internal walls) and DRLs are normally smoked.
As for blackout of the balance of the front, all a black grille will do is make the chrome surround of the bowtie and clear lenses of any optional fog lamps stick out like a sore thumb.
To "dechrome" properly in addition to the black badging and stick blackout surround window trim of the RST, I had to pi$$ away another $200 to buy a lighted black bowtie which has a matching normally smoked surround (when not lighted) and another $10 for a partially smoked plexiglasscover for the fog lamps.
DSCN0604.JPG.8e07c45525472d7f449571b20779044c.JPGDSCN0937.JPG.d2a2e5cfd1efa826661d79a213a0e6c6.JPGDSCN0926.JPG.4dfcca3831527e84eda3737d858b34a3.JPGDSCN0623.JPG.2cf3b32bb8caf0a6b2a2104798e2b5ac.JPGDSCN0935.JPG.f5fb34082d422a6947c8f023d5854e92.JPGDSCN0936.JPG.6c1e7ba9f1db678f49a5a97aa4bd0baa.JPG
They are different.  See my post directly above yours.  Midnight LT Trail Boss uses the High Country full LED headlights.  Has not only the DRL >< but also LED signal.
RST and LT Trail Boss have the LED headlights but the signals are regular bulbs.
Edited by newdude
Thomcat, I think in your last pic you can tell its a  different DRL (LED strip is much narrower than the HC/mignight headlights).
To be honest, I like the standard DRLs on the Trail Boss better. The slim DRL looks cleaner and I like the carbon fiber fill in. Also, I changed my bulb in the turn signals to the Lasfit LEDs and they are perfect.
I see that now, but the wider DRL/directionals have a clear lens instead the stock smoked ones on the RST you would expect those lenses to be smoked like the headlights.
Is that custom or did you order those fog lamp covers?
Sorry to thread-jack. But, have you had any issues (namely hyper-flash) with the Lasfit LED turn signal bulbs?
None whatsoever. I heard that it’s the bulb overheating when that happens and all you do is turn off the signals and let to cool then it goes back to normal. Since that was the case for some I just avoid using them for a long period of time such as leaving hazards on. I will say that the light is crisp and clean.
Awesome, thanks for the feedback!
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
