my center console wont open so have to go to dealership, I am pretty sure they are gonna have to replace it, idk if they can just get the lid open and not too sure they wont break it or something else just trying to get it open (I have tried and its jammed pretty good)....what are are my chances I can get a full center console (upcharge maybe?)....I think the whole console comes as a complete unit with seat as well, since I wont have one to sell after upgrade to recoup.....they should have checked vehicle over imo….I wanted bucket seats but their wasn't any available unless I went up to LTZ....anyone have any luck scoring an upgrade from defective part, I actually wouldn't mind paying a lil extra at all for full console as long as I get bit of deal for headache
I am waiting for dealer to call me to let me know my local dealer has a FOB and manual before I make appt for console
Edited by Dunn
There was a thread about this awhile back, I'm not 100% sure but I don't think there is a lid that opens on the LT trim trucks.
That would make a lot of sense why it won't open ????
Both my wife's 2020 HD 2500 and my 2020 1500 are LT's and they have opening lids on the consoles.
Can you post some pics of it open on the 2500, curious on what the latch mechanism looks like.
Maybe we can help the OP with what might have failed.
LT console opens, I specifically got this trim level because I am well aware of the custom trim that doesn't open....it has the latch, you can feel it wants too, but the pin is stuck or not engaging far enough to release it....I just traded in my 2019 RST with same console
on the custom and WT there isn't even a latch to press....mine has latch its just stuck and I can get it open if I break it but then it becomes my problem....currently its theirs to deal with
was just curious as to scoring the full floor console since they probably have to replace it anyway, I doubt they will even try and probably break it anyways, most likely they will just unbolt it from floor order the whole thing and send this one back....that's my guess anyway
Edited by Dunn
9 hours ago, MTU Alum said:
Work truck and custom trims don't have center console storage.
#iworkforGM
you thinks its possible I could just get upgrade to full floor console for bit of an upcharge?....idk what dept you work at over or is it not even worth bringing it up when I get there?
Edited by Dunn
  • 7 months later...
I'm having the same issue. 2020 Silverado 2500 HD LT Z71 package.  Anyone know if there's recall on the latch?  It seems the fold up seat and the cover operate on the same locking mechanism.  When the seat can be moved the cover stays locked  and vice versa.  On mine the seat won't lock into place and the cover won't release.  It's happened twice now.  The first time a few months back.  By chance, I was able to free it up the first time.   This time not so much.
Edited by 1JB
Spelling
I had this problem when I picked up my truck new from the dealer. The salesperson said she didn't think it was supposed to open. I told her it has a latch. It has to open. I didn't want to break it by forcing it. So she called someone over from the service department and he fussed with it for several minutes and finally got it to open. It hasn't been a problem since.
yeah i got mine to open with a thin metal bar and some pressure to pull forward and up for the latch back far enough to release it.......same as above hasnt been a problem since.....now one of my power folding mirrors wont close
My local dealer was able to fix the problem. The console lid and jump seat latch are set up to operate dependently.  If the jump seat is in the open position for seating, do not open the console lid.  That's how the latch locks up.  If it does happen, you have to pull the rubber cup holders out to access and loosen the latch mounting screws.  The cup holders can be removed easy enough, they just carefully pull free from the console lid.  With the screws loose, the latch can be moved a tiny bit to release the lockup.  The Servuce Manager told me the latch is not normally adjustable so don't mess with it if you don't have to.  The service trick might save a trip to the dealer.
Edited by 1JB
Spelling
  • 3 years later...
2023 custom trail boss, center council won't open, when you pull on the handle to open it feels like it is almost going to open, I have never even lifted the council for anyone to sit there. Pretty disappointed, esp for how many miles are on it, and I felt like an ass an was very embarrassed when I went through the drive thru at McDonald's and couldnt get to my money to pay.By reading through the posts this seems to be an issue in alot of chevys old and new, surprised they haven't fixed the issue.
    Sdid
    Sdid
  • Who's Online   7 Members, 0 Anonymous, 1,489 Guests (See full list)
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
