Trying to decide 2016 2500hd Gas vs 2018 2500hd diesel
We went through this exact same comparison a couple years ago. We decided the gasser was the best way to go. We tow our travel trailer (8,000lb) a few times each year through 8% mountain passes. Sure we aren’t first to the campground but I also don’t run it into
the ground either. The other 355 days per year it sits in the garage half the time and the other half it’s used to run errands. I would’ve loved the diesel but I can also buy a lot of gas for the extra 10k it would’ve cost up front. Go with gas if you’re not hauling the majority of the time. You do no justice to a diesel engine if you’re not working it.
I know which one I picked. :rolleyes:
but everyone's needs/wants/usage/etc/etc are different.
I certainly no longer 'need' the duramax but I like the way they drive.  Tried both 5.3 and 6.2 1500's, but came back.
Watching the 3.0's closely....
The exact route I took. Really wanted a 2011-2014 Sierra duramax, but finding one in red, fully loaded, super low miles was to difficult. Found a nice 17’ gas with everything I wanted and the price I wanted to pay. Mine sits in the garage pretty much all the time. 3 years old and 12k on the odometer.lol.
On 5/28/2020 at 1:24 PM, Waaazooo said:
Wow your toy hauler is light. Our trailer is 34’ and is 8k dry and 11 wet (approx). It pulls fine. I was just considering if the gasser would pull equally. I don’t need to pass cars on 3% grade.
No gasser will pull the same as a diesel. A 6.0 will pull your weight but it will definitely work. I pull about 10,500 with my gasser and it does ok. No grades here in Florida.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
