So a further update after a month in the shop they replaced lifter guides and fuel rails and gave me truck back and said it was cylinder 2 lifter bleeding out that was causing the misfire which felt like people a stutter at low rpms. So since this shaking started they replaced camshaft position sensor and that wasn’t it. Now they have replaced lifters cause cylinder 2 had a bleeding lifter and that wasn’t the problem either. Truck still shakes and stutters. Does any one see a problem with this I’ve brought truck in twice with no CEL and they found big problems each time but still haven’t fixed the problem the truck was brought in for. This seems unbelievable. The truck has only 1200 miles now and its two months old and now is going in shop for the third time to fix same issue that hasn’t been addressed but they keep finding bigger problems each time they look into it. I’m at disbelief did they just rebuild the top end for nothing. Furthermore on paperwork they stated they test drove vehicle after repair and it was fine. But I looked at the Chevrolet app and it says no miles were driven on my truck after the date they said they repaired. This thing is becoming highly suspicious I’m not sure the dealer is doing anything but giving back truck after holding it for a month
  • Sad 1
Picked up the vehicle after it spent a week at the dealership.  They replaced a valve cover gasket for the leak. second time they replaced a valve cover gasket. and said as far as the shake is concerned, it's a normal characteristic of the 6.2 and mine is better than most. Blowing smoke up my a$$. I'm going to have an outside shop diagnose the issue and pursue lemon law. I'm done with this POS. 70k dollar pos. It's a shame.
I end up selling mine to CarMax, I was able to recoup all my money back with the high prices on used cars.
I didn't try the lemon law because I will end up losing a significant amount of money . Texas lemon law said that the dealer can deduct the usage(millage) of the vehicle at the time of them purchasing back from you.
I loved the truck but like you I got tired of dealing with this issue and who knows what else in the future.
  • 1 month later...
I had this same issue recently on my 2021 Yukon AT4.
- no engine light but same symptoms mentioned in above thread
- replaced valve body (no change)
- replaced torque converter
- - O2 sensor warning comes on
- Replace O2 Sensor and shutter/shift problem goes away and increase MPG +3
My Recommendation if no engine light or error message is showing then change out O2 sensor. Mine didn’t show as bad till the torque converter was replaced.
Bad O2 sensor symptoms reflect the issues in this thread.
Hello my 2021 5.3 AT4 shakes also… I noted it after doing the K&N CAI and exhaust..
then at 8127 my # 6 lifter blew .. after repair  it just shakes all the time while going slow!
I return it to stock filter and it got 80% better but now with Air conditioning on it is more noticeable. A/c Off near perfect
I don’t know but Dealerships say it is operating to Spec but I doubt it.
during lifter warranty work they also replaced #1 cylinder plug for misfiring and it was fouled.  So I will soon be going to Mobile 1 oil and all new plugs hopefully this helps
Back from a new dealer, after the last damaged my car and repaired it without my knowledge, I refused to take it back to them.  New dealer found a misfire code on the same cylinder as the failed lifter, and replaced the spark plug. After the lifter failure, plugs never replaced nor were they replaced on subsequent visits. This is visit #4 for engine failure since August and just a little over 1k miles since original failure at 4700 miles. Misfire at idle is essentially gone, however shake/misfire still prevalent on light acceleration.  I notice it all the time when warm. After a hard acceleration to pass or accelerate to get on the highway, then relax and maintain a speed while just applying just a little gas or coasting. I'll drive it around for a bit to get all monitors back up and hopefully another code will pop up to lead to the problem
  • 3 months later...
I guess I've been lucky, but the sputtering and whining started yesterday.  I have a 2019 Trailboss Custom with 93K miles.  I thought it was just a bad tank of gas at first, but there is also whining from what sounds to be in the transmission.  It goes away when I drop the throttle, but comes back at low rpm.  I've looked at the belts and they all seem fine.  Oil and transmission fluid are good too.  Anyone else with a custom that has had these issues?
  • 9 months later...
JUST got a 2020 Silverado 1500 custom. It does the same thing your description was perfect. It only has 43k miles. At first I thought I went off the road and was driving on rumble strips on the sholder.
This is certainly not what we like to hear, O A N.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2020 Silverado 1500. To do so, please send an email to [email protected] with ATTN: O A N/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
I have the same issue with my 2022.5 Sierra SLT 6.2L. I really hate that shuddering issue. Very sad for a $70k truck to have so many issues including the trailer brake issue I am deal with as well. Shame on you GM for such a crappy product.
This is certainly not what we like to hear, capitalst.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2022 GMC Sierra SLT. To do so, please send an email to [email protected] with ATTN: capitalst/GM Trucks in the subject line.
www.gm.com
My 2022 1500 2.7 4x4 has recently started having noticeable vibrations at 9,000 miles.  It began with only vibrating around 23-25mph (mostly during gentle acceleration and cruising at speed) but has increased to vibrations at multiple speeds.  The vibration isn’t noticeable on more aggressive acceleration, but feeling like driving on rumble strips if you are cruising at speed.
     I have taken it to my dealership 3 times within the past month with nothing being resolved. (2 of those the service manager and a technician rode with me to verify the vibration after they said they couldn’t replicate it on the first visit).  They have asked me to drop it off again next week, but do not have a plan of action.
     I was hoping someone has had their issue resolved so maybe I can point them in a direction, since it’s starting to seem like the dealership is just holding the truck for a couple days at a time and returning it without trying to resolve the issue.
thanks in advanced!
  • 2 months later...
I am a lifelong GM truck and tahoe/burban owner and am losing my mind on this issue.  we have had a variety of them for our multi location small business, not exactly a fleet operation but have had enough trucks to know when issues start to present themselves.  I'm on the road with regular towing and loading, 500-700 miles a week on my daily driver which isn't the most in the world but isn't nothing, mostly two and four lane highway miles, weekend gravel and dirt use in the upper midwest so a lot of four wheel drive all winter.
My last daily driver was 2016 Tahoe 5.3 V8 on 6 speed transmission with 3.08 gears.  changed torque converter at 50k and slightly improved, changed tranny fluid again around 75k, the truck got slightly worse each time and did it until I traded it for a 2020 crew cab LTZ/Z71 Chevy with 8 speed tranny and symptoms started around 40k.  Been working with the same GM certified shop for decades who found the TSB, changed the tranny fluid and gear boxes.  improved slightly but getting worse gradually, replaced a front bearing for noise but now at 90k on the 2020 and just took it in today for an oil change and having the shop check it out again, the low RPM at both high and low speeds is as bad as it was at 40k.
still own a 2009 HD 2500 silverado snow plow truck with 200k miles on big block V8 and never had any low RPM shake, several crew cab silverados with the 5.3 L V8 before the 2016 Tahoe and also still have a 2011 GMC yukon XL with 160,000 miles on the 5.3 V8 that has also never had this issue.  It has got to be something they've been using just these last two generations.
  • 1 month later...
I had issues with the transmission shudder back in February of this year at 19175 miles. The dealer did the recommended flush and the issue seemed to go away until a couple of days ago. At first, I thought it was the road I was on because it was a rough road. The other day I went out of town and noticed it under light acceleration, and it started to do it at steady speeds. Also, if I accelerate hard and let up the rpm's do not drop back right away, and it takes some time before it upshifts. Looks like it is going back to the dealer again. I am starting to wish I had my old 2008 2500HD with 217500 miles back. I only did normal maintenance and repairs on it, and it was running and driving fine when I traded it in. The only reason I got a newer truck was because of rust from the road salt Ohio uses.
  • 1 month later...
I have the same exact issue. The issue could be the same as mine. If you have normal square blocks from Chevy, they are not angled. You need tapered rear blocks.
If you guys have factory block as a lift and you want to keep the factory blocks just order 2.5 degree shims. This will angle the rear diff so the pinion on the drive shaft is inline with the transmission. Chevy should have these included but it took me forever to figure out the issue
https://amzn.to/3pbzmdj
Throw these on your rear leaf springs and point the narrow end towards the front and the thick end towards the back. that should fix the issue.
    tblt44
    tblt44
  • Who's Online   5 Members, 0 Anonymous, 822 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
