On 7/2/2020 at 8:36 PM, RJ3 said:
Which taillights are those ?
Stock taillights.  Just had them tinted with a film.
On 6/22/2020 at 10:11 PM, Jaychevy81 said:
TVS1900 and worth every penny 5.3 dyno 480 HP8b357f68a41c30bed69d5e9540d4a144.jpg
How much did you gain off stock?  Any other mods like exhaust or cai?  Running magnusons tune?
It has cat back magnaflow the supercharger came with a CAI. I had it dyno tuned it put down 480 to the wheels.
So here is the update, on the intake where you put the gasket to seal the supercharger they have dowel type locators installed.  one of these was keeping the s/c from fully sealing even though it looked flush(gasket was basically floating around and got damaged). Obviously this caused a vaccum leak. waiting on new gasket and corrected the dowel issue. Will get back soon to let everyoneknow if this solves my main problem. what year LT4 PLUGS  did you use jaychevy? and what gap? thx for everyone's input
On 6/20/2020 at 10:25 AM, Sbrick said:
Recently picked up a '18 6.2 silverado centennial edition.  Added a borla s-type catback system.  Installing a Magnuson TVS1900 Supercharger.  Had thought about throwing some long tube headers on it after that.  Anyone have some insight as what type of mods they'd install to compliment that setup?  Anyone have experience running a TVS1900 setup?
Nitromethane!
16 hours ago, Grumpy Bear said:
Nitromethane!
radar detector...lol
  • Haha 1
Good to know, I like the look......
On 7/25/2020 at 11:03 AM, Sbrick said:
S/C is in and tuned.  Just figured I'd share the dyno results for anyone interested....
Are you running stock tire diameter? Assuming you've got 3.42 gears as well?
I'm getting ready to install my SLP TVS1900 in the next couple weeks. I'm running 35x11.5xr20 Nitto Ridge Grapplers and dyno'd the truck a couple weeks ago for a baseline. I have 3.42 gears, 87 pump gas, CAI, stock tune, the truck turned 273hp @ 5200 and 313 lbft @ 4200.
Glad to hear you got your issues worked out. Roush owns SLP now and when I called I got no help with tunes as you've experienced. I'll be going back for a custom tune once I get everything bolted up.
Sorry this was meant for Wilshire37. I see yours is a 2018 6.2l.
Edited by Dick Lichon
That's a sweet setup.  I had a blacked out sierra I setup like that.  You'll enjoy that blower when you get it tuned.  I know I have no regrets.  May install a 3.1 pulley instead of the 3.4 eventually for a lil more boost
7 hours ago, Sbrick said:
Thinkin about going one temp cooler on the plugs and gettin some upgraded coils and wires.  Anybody have recommendations?
waste of money messing with coils
  • 2 months later...
Wondering if I have my catch can routed properly to the SC? It seems to be working well removing oil vapor and moisture. Your thoughts?
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
