Just now, nutdriver said:
I just looked at my build sheet.  I do have WMI listed as reflected in the screen snip below labeled as "SALES PACKAGE - CONV PACKAGE."  I do not have shutters.
WMI is shutters.
Here is a photo through my front grill.  I assume this is consistent with my truck not having shutters despite having the WMI build code??
1 hour ago, newdude said:
I'd double check your build sheet.
Ran some 2021 2500hd Duramax VINs without plow prep and they all had shutters in the build.
I also checked the 2021 MY production option changes, WMI shutters were never deleted/removed during the production run due to any current events.
I don't have my build sheet, so I dug out my window sticker and it indeed has the snow plow prep/camper package listed. So you are right, I'm just an idiot and overlooked/forgot it was on there.
I lookup and keep a spreadsheet of all the RPO codes of my vehicles I own and that's what I was referencing to see if I had the snow plow package. My truck does not have the "VYU - PROVISIONS-SNOW PLOW PREP" or the "WMI - SHUTTERS-FRONT GRILLE, ACTIVE, UPR AND LWR" RPO codes which is why I was mistaken.
I wanted to provide an update to my saga.  I have tried a few times to take a look to determine whether I have shutters on my 2021 Denali SRW Denali 3500 Duramax.  I have previously only looked in the light of day and the view of radiator fins was prominent.  Tonight, I took a closer look using a bright LED flashlight  after dark.  The view was much better and I was able to confirm that I do indeed have shutters. Really a big shout-out to newdude who provided excellent assistance through his posts and some private emails!
On 6/23/2020 at 9:01 AM, unit said:
Diesels don't have the shutters, gasoline engines only.
I have a 3.0 with shutters
On 11/11/2020 at 8:29 PM, CHIp070 said:
Anyone with active air shutters missing the top left blade? Dealership told me this was normal.
I know old post but found this while researching a P05AE error code on my 2020 2500 Diesel
TIP: On 2019-2021 Silverado 1500 and Sierra 1500 models and 2020-2021 Silverado 2500HD/3500HD and Sierra 2500HD/3500HD models equipped with upper and lower shutters, the top passenger-side louver/vane of the upper shutter is intentionally missing from the shutter assembly for airflow reasons. Do not replace the shutter for the missing louver/vane.
https://gm-techlink.com/?p=16027
ofcourse diesels has shutters to, it is standart on any gm trucks, because of shortage some people are not lucky to grt what thry already paid for it .
On 6/23/2020 at 9:46 PM, unit said:
That's a conundrum  for sure.  I can't imagine why engineers would put shutters in front of that giant charge air cooler and radiator.  As I stated above, my 2020 LTZ 2500HD does not have shutters.  I can see where the shutters would fit into the front grill work for gasoline powered trucks but I didn't think any diesels had them.   It will be interesting to find out what the thinking is on them.
i haves 2020 2500 diesel high country and very happy having the shutters, it is a very useful during the winter, helps engine warm up quicker, i dont think it is worth the have on gas trucks, doesnt do anything with MPG either.
On 6/23/2020 at 7:19 AM, H1ghlndr said:
I have a 2020 Sierra HD AT4 3500 SRW Duramax built 1/29/20.  It does not have active aero shutters in front of radiator - looks like it has the holes for each shutter, but no shutter.  Didn't really think about it until watching a YouTube duramax channel with a grille off a 2020 and there were active aero shutters.  I have no codes so I wonder if this was intentional from factory?
Do others have (or not) these active aero shutters shutters on their 2020 L5Ps?
it is standart on every gm trucks,some people doesnt get it because of shortage and no credit paid to the buyers.
On 6/24/2020 at 9:40 AM, H1ghlndr said:
I don't have 5th wheel, but snow-plow and towing as part of 3500.  I am wondering if people with no shutters have an option like snow plow prep or something else?  Weird that there are 2500s with / without.  My initial thesis was 2500 and them and 3500s didn't.
What options do people have with and without shutters?
i have it on my 2500hd high country, i like it in the winter, helps engine warm up quicker, so you really dont need a engine cover for the winter, when it is come to MPG nothing, worthless on the gas trucks but every gm trucks comes with it standart, a lots of trucks missing shutters but nobody complains about it and no credit paid to the buyers, you just have to pay attantion when you buy anything new .
My 2024 2500 HD Silverado has the 5th wheel and snow plow options. It did not come with the shutters.
My other 2024 without these options did have the shutters.
I think it has to do with the plow package . Snow plows can block air flow and cause high engine temps .
Just my opinion
Edited by John1964
No RPO VMI when I scan the door jamb sticker, but it appears my truck has the shutters:
Just chatting w/ brother. His 2024 Dmax has the plow pkg & no shutters.
EDIT: His 2022 Dmax w/o plow pkg had shutters.
Edited by revrnd
    Sdid
    Sdid
  • Who's Online   7 Members, 0 Anonymous, 1,489 Guests (See full list)
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
