12 hours ago, BigDog88 said:
Ive had it higher, lower, currently i have the ball level with the ball coupler.
I have mine setup 2.5” above my leveled trailers ball mount.  I set mine up with 6 links between my bars and brackets.  With that setup I get about a 3/4” of sag in the rear.  Truck rides great, I have about a 5k trailer.
when I was setting mine up it was suggested to have the ball 1.5-3” above the top of the trailers ball mount ( trailer sitting level)
this is the video I used to help me get mine right:
Edited by pewterliftedz
My elevation (x31 with rancho shocks), when hitch height was properly set sagged 3.75". (7k trailer, 600lbs tongue weight, wife, dog, 2 kids, 5 bikes in truck bed).   I ended up throwing on airbags, eliminated the squat easily, still have decent distribution weight on front (need to run over scale for firm numbers).  She pulls really really well with my 7k trailer.  Ill post up bunch of pics friday when we hook up for our long trip, including sag with empty air bags, etc...
Yeah some pictures would help to see what you’re talking about. I have a 4” lift and used a drop hitch on my WD, and was able to get it to distribute the weight properly. Unless pulling a very light trailer, you’ll probably always be able to visualize some sag. Mine is about 7K loaded.
This picture was from my first test run, and I was able to eliminate even more sag after adjusting the WD.
I appreciate everyone response to help.  This is only picture I have from when I had the ball higher than the coupler.  It’s not a great picture but shows the squat.  I’ll have to go hook it up on another day when it’s not my wife’s birthday, and take better pictures!
Too much squat.  It looks like the WDH bars are parallel to the frame which is good. It's hard to tell but it looks like there is no downward head angle, which would indicate not enough weight is being distributed.  Good news is this is an easy fix.  Watch the video I linked on how to setup an Equal-i-zer, especially the part where it shows you how to tilt the head down more.
I'm level with an 800 pound tongue weight.  Looking at your trailer, looks like a lot of the weight is forward of the axle for a large tongue weight. I would estimate your tongue weight to be well over 1000 when loaded.  Also, the Sumo springs ride like trash and the Firestone air bags do not fit correctly (tried both).
Edited by bshort
12 minutes ago, BigDog88 said:
861 lbs of tongue weight
Have you ever jumped on scales to see how much weight is being distributed to the front axle?  Did you have anything loaded in your bed when you took this photo?  That is a lot of sag for sure.  I'm not familiar with your WD hitch style unfortunately, mine uses the chain links.
That model looked to show that as dry.  That's without propane, battery, any water and your stuff.
Nothing in the bed in the picture
Your correct that is dry.  So probably around 1k with propane and battery.  I try to keep minimal water on travel days just enough to run toliet for stops.
You have an Equalizer hitch correct? Do you know the weight rating of the spring bars? if they are undersized or marginally sized you can replace those spring bars with a heavier weight. I would only go this route if the hitch geometry is set up correctly and there is still too much sag.
Edit: after looking at that pic a little more closely the trailer looks fairly level as well as the spring bars you probably need to look in to heavier weight spring bars, likely also a helper spring or airbags, even with heavier spring bars that is several inches of sag to compensate for.
Dumb question is it mildly difficult to snap the bars up in to place when hitching up?  I switched to a different style because i kept wrenching my back doing it.
Edited by Greyhound6.2
Had to get something out of the TT today and looked at the sway bars quickly and they are rated for 1k tongue weight max and 10k trailer weight max...so technically I should be ok.
im going to add more washers to the hitch to angle the ball back farther and see if that helps.
I rarely use the tool to get the sway bars on it...I just have jack lift it up high enough that I can swing the bars on effortlessly. Thanks
Couple of photos
1 is with no air in bags, hitch height 21”
2 is connected no equalizer bars no air bags sags to 17.75”
3 is equalizer bars but no air bags 19.25”
4 is equalizer bars and air bags up at 40 psi   20.25”
I have a levelled 2019 Sierra, Max trailering option. This truck sits higher than my last truck overall so I actually lowered the height position on my WD hitch to prevent our TT from going down the road with the front end pointed up.
Hooked the trailer up today and overall the trailer sits level now but my truck squats.
I’m sure the levelling kit doesn’t help.  I measured about 5 1/2” inches between fender and top of the tire up front and about 4” from tire to fender in the back.
I’m sure airbags would really help, especially for trucks with levelling kits.
I also have quite a bit of weight in that toolbox I have on my truck.  When on holidays I’ll empty that out, although probably have a load of firewood in the truck anyways.  Just make sure the firewood is pushed as far forward as possible.
Myself at 170 lbs, wife that is 105lbs then 3 kids in the back seat come in around 160lbs total will mean a fairly loaded truck but well below the limit I’m sure!
Edited by madconcept
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
