2004 SS Silverado
I have a 2004 ss silverado awd and I recently lowered it I drove it around for a couple weeks then one day is started to shake really bad like the “death wobble” I’ve changed pitman arm and idler sway bar bushings and also end links everything else is fine having a hard time figuring out what it is took it to an alightment shop and they had no clue and wouldn’t align my truck
Could it be the new angle of your driveshaft?
I had a 2004 SCSB with a 3/5 static drop without the proper shims installed, shook like a unbalanced washing machine at freeway speeds.
Look at your front driveshaft u-joints and cv axles if you feel it from the front.
The front drive shaft u joints where recently replaced but will check
52 minutes ago, davester said:
Why wouldn't they align your truck?
They said I had too much camber and had to have custom upper control arms
