21 hours ago, Jav_eee said:
You’re right. I could’ve swore I saw a similar warning with the 1.75” kit. It’s crazy that only .25” more height requires that warning.
Sometime a little goes a long way. A 1/4” on a taper or angle over a distance could end up being significant .
Thats why I called motofab, fabtech readylift and asked some questions.
According to motofab if you do a lower spacer its safer as you do not run into ball joint angle problems at full droop.
Now a top spacer is not ideal on these trucks and even the bottom spacer they are recommending 1”. Hence why they arent offering options for taller levels.
My thoughts are Ready lift is doing the max bottom spacer which should be comparable to the motofab in dimensions , but its the additional top spacer which is causing the issue of ball joint angle at full droop.
This is why they include uca in the kit.
So in summary if you went to increase your front end clearance by 1”, it would be nearly level. You could go with the motofab spacer which is easier and quicker to install and less costly.
Motofab stated the 1” spacer in the front maintains GM tolerances for both ball joint and cv angles. So just another avenue , some might want more height than the 1”.
Although the motofab lifts a full true 1” and the ready lift I believe is called out as 1.75 but actually does 1.5. So its not far off.
So what is the concenous on all the leveling kits for TB’s? I was leaning toward the Ready Lift 1.75” with the new UCA’s but now I’m unsure. This truck will be pretty much a pavement pounder and maybe a few times into the woods to drag out a bear or deer.
So the the Trail boss factory lift entails the following.
Mechanical
Different CV shafts, new front impact horn lowering adapter, taller front struts, longer rear shocks, rear spring spacers, taller jounce bumper mount, u-bolts/nuts, and longer reach bottle jack
Mechanical
Correct.  But the bottle jack was the EXACT same part number and reach as the stock jack that came in my LTZ.
The main thing to look at here is the CV shafts. They are different on the Trail boss and AT4 then a standard 1500
1 hour ago, Jmccracken1214 said:
I bought the motofab 1” spacer last night. Excited to get the front up a little bit more than it is currently.
whats the largest tires I can run on the factory 18’s without issue?
Ive been scouring for info on this. So far Ive found that on the Trail Boss, 295/70/18 will work. Seems its the wider tires that present an issue, 12.5” for example which are easier to find in more options may rub.
Sucks with the 295’s that there aren’t a lot of options, I’ve seen some on here running 35’s in stock wheels, but then read some can’t.
had an offer for $450 for my factory duratracs with 6600 miles on them. Is that fair?
Im in Canada, I have 1000-1100 miles on mine. Only because I took a 600 mile trip on the highway. Im going to post mine for 800 canadian. I think they are 3-325 a tire new plus tax and rubber fee etc.
Im someone offers 700 I would consider it for me. 450 us is about 600-625 canadian atm. To give an idea.
On 8/13/2020 at 8:43 PM, Chips said:
This is incorrect , its not a leveling kit on the trailboss , its a lift. And the UCA on the trail boss are not the same as ones on a regular 1500, so they have already compensated for any ball joint angle from the factory. You are just leveling the front end , there are 1” levels for the TB that have  nearly 0 effect on ball joint angle so no need to change UCA.
But to each there own. People have done the level with UCA and experienced failures lol, bad installs are bad installs .
This is false. The upper controls arms for both the trailboss and the standard height 1500's are exactly the same part number as looked up by VIN numbers in GM's parts catalog. As well, GM offers the factory lift as an accessory package that also DOES NOT include control arms.
Yes its the CV that is replaced on the Trail Boss vs standard 1500. The premise remains the same its not simply a leveling kit.
Any updates on the 1”? I’m considering the same. I currently have 35x11.5x20 without level
Nope, got a tracking # today but hasn’t updated yet. Hopefully I’ll have it by the weekend and have it on the weekend after. I’m going to put it on myself. Doesn’t look hard at all.
Edited by Jmccracken1214
So the verdict is that the 1” block is safe? I talked to my dealership and they use a rough country 2” that goes above the strut. It’s $900, takes all day to install and yields 1.5”.
Did you order the gmc 1” or at4 specific 1”? Motofab told me they are the same thing but the at4 designation is $3 more
Edited by Fsu96
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,008 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
