I got my 2019 HC in October of 2018 and my rear window started leaking last Friday (8/7/2020). I called the dealer as soon as I saw the water and I told them I had 36,8xx miles. I dropped it off Monday (8/10/2020) with 36,9xx miles and the dealer said that warranty will not cover the cost since I'm over my 36,000 mile bumper to bumper coverage. A service bulletin came out in February 2019 but since mine never leaked I didn't want them touching it. Am I wrong for saying that warranty should cover it since it is a known problem?
Update: I called and the seal was cracked and the rear window is separating. They are replacing the rear window and seals.
Edited by drucker
update
1 minute ago, cmysstailights said:
Contact corporate
Phone number?
If it is a known defect, tsb or recall I would think it should be covered regardless of the warranty, but not 100% sure.
I think these guys use every excuse in the book to not do stuff for free. My bet is you’re on the hook for the bill. Keep us posted.
This will be the exact reason why I will have to end up dumping my truck or replacing the rear with a solid glass window at 3yr/36k miles.
They have already made three attempts to resolve this issue on mine in less than 9 mos.
GM has no plan to fix this defect properly and has not given any confidence to their customers nor provided transparency on their efforts.
New trucks are coming off the assembly line with this same part today and GM knows it has a problem.
The dealership has a body shop doing the repair and they are waiting on the new window. The dealership said gm has a new part number window that just came out. The window should be in and installed today and I will pick  it up Monday afternoon. Here is a picture of the truck. They didn't take the rear window spoiler off. The dealership also said they were going to ask GM to cover it under warranty. I have already called GM customer service and I have a case number for this.
35 minutes ago, drucker said:
....The dealership said gm has a new part number window that just came out.....
when you get that new window installed, please post a picture of this info from it like this.
I sure will.
I got my truck back today and it costed me $384 after I talked to customer care and the dealer. The dealer said they came to agreement with GM that I had to pay 40% of the total bill.  I didn't see the actual total to calculate the 40% so who knows. Here is the new window part number that they waited on. The window was built 7/29/20. The dealer said this was a new part number but I don't know. Maybe sooner one on here can tell me.
Sorry to tell you this, but that window is the exact same one they installed in mine in February as you can see our pictures match. Yeah, it was a "new part" over six months ago when it replaced the E2. However, my E4 leaked just over a week ago, there are others on this forum with leaking E4s, and you can see the updates I've posted in the main thread on this recently. You should check that they added the sealant on top of your new window as my dealer said that is now the current process even for replaced windows.
    ncleg
    ncleg
  • Who's Online   6 Members, 0 Anonymous, 708 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
