Yup, hook it and carry on.
I've said before on here, a local construction company near me gets in new trucks all the time as they have a huge fleet of vehicles. The 2500/3500's will have a goose neck trailer hooked up on first day on the job as a new work vehicle, 200,000 miles later it's replaced with a new truck.
I strongly recommend getting her a few thousand miles before towing.  I do believe it does some good getting things worn in well.  Get your first oil change done, and then still plan on changing out the front and rear diff fluid as well as transfer case fluid at about 10,000 miles.  I for one see that people who take things easy from the beginning with their trucks and break them in slowly and properly tend to have the least amount of issues in the long run.
I picked up my 2500hdAT4 gas on August 15th, so far very pleased with all aspects of the truck. Took about a week to get used to the size and driving characteristics from my 2014 Sierra 1500, but nothing major, parking and narrow roads are fun.
 I took the truck on a long trip Monday 8/31 about 600 miles total to the top of Mt. Washington Auto road and back. It got a respectable 15.5mpg all around. I thought that was fair given going up an 8 mile auto road was steep and coming down I was in low gear. The truck rides good and is very comfortable.
I just got back from towing my travel trailer for the first time, it is light for this truck at 7700lbs fully loaded, so i would say arounf 55-6000 with all of stuff in it. Truck was confident had plenty of power and had awesome grade breaking compared to the 1500. I got around 9.4mpg for the entire trip, which is ok, i saved 10k from getting a diesel so i knew fuel cost were going to be more.
Overall after 1300 miles in about a month I love this truck. Not a lot on the road so it feels unique, gets a bunch of looks and it will be pulling a fifth wheel in the next 18-24 months hopefully. I feel full confident in it's ability, the extra weight and added payload and power are awesome. Like you guys said a mild tune and it will be unbeatable.
Mike
I tend to disagree that mileage is terrible while towing on a cost per mile basis. Between varying fuel cost gaps between diesel and gas, def cost, oil , and filters the difference is narrow. Post emission diesels towing what I tow seem to be getting between 10 and 11 mpg vs. my 9+. Right now diesel and gas prices are more or less a wash but typically that has not been the case. Even with this recent development maintenance and initial price difference makes strong case for gas assuming your towing needs fit in its capability.
  • 1 month later...
The owner's manual says to wait 500 miles before towing, and to change oil before first tow.  This is not under break in, but first paragraph under towing section.
I have 8k travel trailer and load the truck to 9.3 k lbs when traveling.  I just traded a 19 dmax for this 20 Gasser.  It is plenty powerful for me, and more fun to drive than the dmax.
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
