Mine went in today for complimentary oil change and tire rotation. I have a little over 6k miles. I let them know about the noisy brakes and tech bulletin. Service adviser asked me if they do it hot or cold, I said mainly hot.  Mine get substantial worse after unhooking from my 24’ enclosed trailer. I will let you guys know what they do later today.
Got the truck back today.  New rotors installed after they discovered there was glazing/hard spots on them.  Took them a day or so to figure and get the higher powers of Gm warranty to approve.  Just picked up and quiet for now.  All under warranty
Well...spoke to soon as the brakes have started up again with the noise, though not as bad as 2 weeks ago.  Called dealer, stated they only replaced the front rotors and left all of the second round of pads on.  I brought truck into my garage and crawled under and the rear rotors have a shiny spot on the inner diameter of the rotors 3/4-1" wide.  Appointment again next week...
I had mine replaced via the TSB, good to go since. They were on backorder so took a few weeks but happy they honored and fixed it. Mine was built SEP19.
So got truck back a couple weeks ago, noise came back after front rotor replacement and new pads.  Brought back again, 3rd time, discovered that the front pads were installed backwards.  Driving for 3 weeks now and silent...
Just took mine in today for brakes squeaking and steering clunk noise. They also did a complimentary oil change and updated the software for a DEF issue?
Of course 9 hours later i get ahold of them and they tell me they could not replicate the brakes squeaking and humming and the steering column clunk... I told them i will be down there in the morning with my videos showing the noises... I even pointed out the service bulletin about the brake pads. 9 HOURS to do an oil change and software update and drive the truck around the block!!!!
Mine is in for the brake pad TSB right now. I had 17,000 miles on it and it was embarrassing to brake when I was driving slowly as they squealed like an old work truck.
I did have the troublesome pads and they are putting in the new ones.
They did get an “out of stock, back ordered” message from GM for the new pads but were able to get a set from another dealer in town.
So what does it sound like when you are having this issue?  I have been trying to track down a squek noise that I can't pinpoint when I'm driving but it is very annoying.  I've checked everything I know of which could be making the noise and it hasn't stopped?  You guys think this may be the issue?
What’s the difference in pads? Have a copy of the TSB? Mine squeal on in cold weather until they warm up (few times braking).
So dealer said the tech said my brakes and odds are perfectly fine. There’s some brake dust which is causing the squeaking and humming which is 100% normal.... wtf??? But wait if I want to resurface my brakes for $133 that’ll fix the squeaking.
Brake dust isn’t causing the squeaking of that was the case my camaro would never stop as the pads dust quite a bit
So just got home from picking up my truck... I gave them the TSB and they said i had the correct pads on. They kept telling me the squeaking and humming is normal and they can't do anything because 1. I'm over the 7500 miles to do the TSB and 2. I have the correct pads... The supervisor said he has a 2500 that does the same and he just lives with it..... i have never had a vehicle that does this and it be normal.... I even showed the service advisor my video and she said that is pretty loud.. UGH...
    Sothpaw27
    Sothpaw27
  • Who's Online   6 Members, 0 Anonymous, 563 Guests (See full list)
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
