Mine went in today for complimentary oil change and tire rotation. I have a little over 6k miles. I let them know about the noisy brakes and tech bulletin. Service adviser asked me if they do it hot or cold, I said mainly hot.  Mine get substantial worse after unhooking from my 24’ enclosed trailer. I will let you guys know what they do later today.
Got the truck back today.  New rotors installed after they discovered there was glazing/hard spots on them.  Took them a day or so to figure and get the higher powers of Gm warranty to approve.  Just picked up and quiet for now.  All under warranty
Well...spoke to soon as the brakes have started up again with the noise, though not as bad as 2 weeks ago.  Called dealer, stated they only replaced the front rotors and left all of the second round of pads on.  I brought truck into my garage and crawled under and the rear rotors have a shiny spot on the inner diameter of the rotors 3/4-1" wide.  Appointment again next week...
I had mine replaced via the TSB, good to go since. They were on backorder so took a few weeks but happy they honored and fixed it. Mine was built SEP19.
So got truck back a couple weeks ago, noise came back after front rotor replacement and new pads.  Brought back again, 3rd time, discovered that the front pads were installed backwards.  Driving for 3 weeks now and silent...
Just took mine in today for brakes squeaking and steering clunk noise. They also did a complimentary oil change and updated the software for a DEF issue?
Of course 9 hours later i get ahold of them and they tell me they could not replicate the brakes squeaking and humming and the steering column clunk... I told them i will be down there in the morning with my videos showing the noises... I even pointed out the service bulletin about the brake pads. 9 HOURS to do an oil change and software update and drive the truck around the block!!!!
Mine is in for the brake pad TSB right now. I had 17,000 miles on it and it was embarrassing to brake when I was driving slowly as they squealed like an old work truck.
I did have the troublesome pads and they are putting in the new ones.
They did get an “out of stock, back ordered” message from GM for the new pads but were able to get a set from another dealer in town.
So what does it sound like when you are having this issue?  I have been trying to track down a squek noise that I can't pinpoint when I'm driving but it is very annoying.  I've checked everything I know of which could be making the noise and it hasn't stopped?  You guys think this may be the issue?
What’s the difference in pads? Have a copy of the TSB? Mine squeal on in cold weather until they warm up (few times braking).
So dealer said the tech said my brakes and odds are perfectly fine. There’s some brake dust which is causing the squeaking and humming which is 100% normal.... wtf??? But wait if I want to resurface my brakes for $133 that’ll fix the squeaking.
Brake dust isn’t causing the squeaking of that was the case my camaro would never stop as the pads dust quite a bit
So just got home from picking up my truck... I gave them the TSB and they said i had the correct pads on. They kept telling me the squeaking and humming is normal and they can't do anything because 1. I'm over the 7500 miles to do the TSB and 2. I have the correct pads... The supervisor said he has a 2500 that does the same and he just lives with it..... i have never had a vehicle that does this and it be normal.... I even showed the service advisor my video and she said that is pretty loud.. UGH...
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
