I have a 2020 GMC Sierra SLT. One of the factory options is adding the bed view camera for $250. Since mine did not come with this, I wondered if it would be possible to add it? Being that it’s only a $250 factory option, I figured it can’t that difficult to do. Has anyone done this or have any knowledge of this?
Not sure how GM wires things nowadays.  I know in the past options like this were simply plugged in, ie adding an entirely different harness for a 250 dollar option was not fiscally viable.  It's likely that the wiring is there already and plugging it in "may" enable the feature in the H/U.
Only an edumacated guess though.
$250 from the factory to add. I believe they run around $1000 to add after the fact. The mirror alone is $500 plus. It has been done and there is a thread on here at one time.
I did it with my ram, don't need the mirror for bed view tho.
3rd brake with camera was $1000 and harness i got made aftermarket as the ram has video plugs in the HU. Then I bought a software pkg from rax jailbreak and also gained the option to type while driving and a few other Easter eggs [emoji1639]
Sent from my SM-N975W using Tapatalk
Why would I need a different mirror? I’d want to view the bed view camera on the display
The mirror is for the rear view camera
You are correct The bed view cam and the rear view mirror cam are both located in the tail light on the back of the cab. I was confused as most people are talking about adding the rearview mirror cam that will display in the reirview mirror on the windshield. You can switch it back and forth. You are correct that the bed view will show on the center display and doesn't need the special mirror. Here is the one on tha Caddy but, it works the same in the trucks.
Edited by 2016 Sierra Owner
added link
I thought I read something about needing a video switcher and software updates to add the bed camera, if you already have other cameras besides the tailgate cam you probably already have one.
You would need the High Mount Lamp /w Cargo Camera, the harness for the lamp, and the coax that runs from the lamp up to the dash. I believe you would then need a GM tech to mess around with your truck to enable the option for you to use the camera through your infotainment system..
No idea if anyone has successfully completed this addition, but there happens to be a high mount lamp and harness on ebay right now if you want to give it a go ?
https://www.ebay.com/itm/Genuine-GM-High-Mount-Lamp-w-Cargo-Camera-and-Harness-84699124/224154116361
"I believe you would then need a GM tech to mess around with your truck to enable the option for you to use the camera through your infotainment system."
This will be the road block. GM won't let the dealer program much of anything into the truck that was not there to begin with. Yes I know they will do fog lights.
I would have thought it would be a simple plug and play. I haven’t removed the lamp assembly and looked, but I figured that there’s already a wiring harness there. I couldn’t see it being anything difficult since it’s only a $250 factory option. Cheap options usually mean fast and easy. If it was $1,000 option, I’d believe there was much more to it than just a simple harness plug in.
I guess I will call GMC and see what info I can find out.
That’s not true, at all. I was looking at two identical trucks. One had the extra bed view camera, one didn’t. The difference in price was $250
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
    • Wait, you guys are changing your oil???
    • If you need that mount looking piece.  You need the air tube.       Cheapest one I see on eBay - 2007-2014 GM Silverado 1500 Air Cleaner Outlet Duct Assembly 5.3L OEM 15901934 | eBay     Same price but free shipping - 2009-2014 CADILLAC ESCALADE 6.2L AIR CLEANER OUTLET DUCT ASSEMBLY 15901934 OEM | eBay
