Hi I just received gm remote start part# 22997089
And are curious where I'm supposed to connect the green wire at.
I want to get all this done so that when I take it to the dealer all they need to do is turn it on. I assumed the truck was wired for it already seeing the plug near the hood latch but guess not. I'm assuming it's supposed to go-to the bcm but I have no idea where that is and what pin slot.
Thank you. 9950c5d6ee6a9dda0f5d5ccb78c63aa7.jpg5a5b51f25b981c1bc1382a49730a3733.jpg3e4a4ed38ff6e3624bc38e6c5df1a384.jpg
Sent from my Pixel 4 XL using Tapatalk
You've got the wrong kit for a 2016 2500HD if that is what you are tying to install this on.  22997089 is a Chevy 1500 kit.
84424016 is the Chevy kit, 84424017 is the GMC kit.  Its just remotes, a hood latch and a recalibration authorization that the dealer has to install.  You also need to make sure your truck has option code AQQ before installing.
Edited by newdude
Ok thank you.
Yea I want to do as much as I can my self hope it lowers shop price.
[emoji1751]
13 hours ago, Gregory Krisa said:
Ok thank you.
Its only 1/2 hour labor for the dealer to install it.  I know our dealer is $90/hr for accessories so it may vary near you.
A straight shot with nothing blocking the signal I can get hundreds of feet away and it still works. Works through glass too, obviously.
Around buildings or anything like that and it's not going to work real well.
So pretty much the same as the standard fob.
Trying to decide if the simple install of this is worth the lack of range as compared to an aftermarket unit.
I went with the factory because of it being tied in with on star and I believe the smart start vs onstar are about the same I'll disable onstar in may
"AQQ" is the code needed to for this work correct? Or is it "AP8"? I've seen both come up in threads about this and can't nail down which is required. According to the AC Delco list of RPO codes they mean the same thing..
  • 1 month later...
Should come with fobs, and paperwork and code, and a good latch.
Any wiring should already be in the truck if you have the appropriate RPO code
  • 4 years later...
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 792 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
