Welcome to this forum!  You will find some very helpful information on this site.  The question you have asked is a popular topic and using the search feature will save you some time.  BTW I am not a fan of this forum's search feature and use Google's instead.
Haha, I’ve asked this question also. It does seem like the collective knowledge base here could provide a quicker answer. Probably would take less time to type 275/60/20(not the answer). [emoji23][emoji23]
I’ve researched, and haven’t necessarily found a 100% solid (to me) answer. Depends on rims too, and the height of mine after leveling isn’t as high as some I’ve seen, measured from ground to fender. So, I’ll probably be conservative and go rims and stock sized, more aggressive tires. I don’t want to trim anything.
I still cannot figure out two things. One is the search on this site is not very precise. How do you use google search instead?
Also, I have the same tire fitment questions everyone has. What to know what is the largest tire I can fit on 18 in rims with my 2020 AT4? Can I do 285 or 295 /70's or 75's. I know the speedo will be off a bit, but I am looking for a slightly different ride. Like the one on my old 2006 HUMMER H2.
I know makes no sense, but its what I like....
TomD
For example, in the Google search box type 2020 silverado max tire size gm forum  You will get plenty of hits including this thread.
I put 275/65/20 Goodyear Ultraterrain on my 19 Silverado LTZ with a ready lift level kit and have no rubbing at all. Basically a 34"x11.5"x20"
well i went with 2" rough country with 33x12.50 on factory wheels and i think it turned out perfect!!! thanks for the suggestions
Looking good, a more aggressive tire on a nice aluminum rim that isn't a 20 looks excellent (more tire less rim is best). It looks nose high, I take it you didn't add a rear block to keep some rake? Also did you adjust your headlights down? That is going to piss off on coming traffic quite a bit...
Tyler
Your truck turned out great, I really like that look. Very clean. I would also encourage you to adjust your headlights slightly. Simple phillips head screwdriver and 30 seconds of your time.
I know there's a lot of these threads but I never get the answer I'm looking for. That's probably because nobody's done it-LOL. I want to add LT275/65R20 tires which sounds like the overwhelming popular size to go with when leveled. But I don't want the 2" level, I am only looking to increase 1.5".  For those of you that can look, say wheel fully turned and in reverse... how much room do you have until your kissing the liner/mud flap? Eye-balling it if your front was lowered by 0.5" (ie 1.5" level instead of 2.0") do you think it would rub? Tire size fit with minor trimming? Or have to do major trimming/or not fit at all.
Thanks. I'm towing more so want 1.5" up front and a 2.0" block in the rear to start with. This hopefully would get me just clear enough for better larger LT/E-rated tires and leveled when hooked to the trailer.
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
