So I'm looking at a 2007 yukon denali 6.2L possibly to purchase. All in all seems solid except for the oil pressure seems really low at idle. I know these dash gauges aren't the most reliable but this seems concerning. 6.2L guys what say you?
If that is accurate, it's pretty low.
The lowest my 2012 ever got was around 20psi hot in the summer and that isn't even at the first line which is 20psi. That's like 10psi if it's correct.
Ideally you'd test it with a manual pressure gauge to confirm. If the manual gauge is higher then it's probably a sensor issue.
Thanks for the quick reply! We are taking it to a 3rd party mechanic for them to go over it tomorrow. We will make sure they check it with a manual gauge.
1 minute ago, Mike GMC said:
Oil brand and weight as well as filter choice can effect pressure.  Do you know what's in it?
Unfortunately not at the moment. I will inquire tommorow
my 2005 yukon had similar pressure at idle in really hot weather. what happened was it used a little oil... and what i suspect is that my wife let it get down there where it was either way hot - because it had two quarts in it - or the engine was coming apart anyway. i never tore it down.. but it was in that period where the GM engines were pretty noisy - especially when they were cold...
Actually found the oil info, forgot we got service paperwork from them. 5W30 motorcraft oil. Oil filter is part number R84060. Doesn't mention brand but google search brings up Carquest
So I've been reading up on this and it would seem the oil pressure at hot idle should be around 20-25 psi.
IF testing manually with another gauge confirms this vehicle is only at about 10lbs I think it would be safe to say this is a vehicle I should stay far away from correct?
It seems likely it would be a oil pump going South or worn cranks bearings if it isn't the 'easy' fix of a new sensor. Or possibly O-Ring around the pickup tube leaking but that requires the pan being dropped.
Any other possible 'easy' fixes? I know I could run some thicker oil in it and who knows it may run for years but I want something mechanically sound not something with a bandaid on it.
The dealership didn't seem to want any part of addressing the issue yesterday. I guess they figure someone will miss the issue and buy it. I'm not looking at pouring a lot of money into repairs. In the end I will probably just end up walking but maybe dealership will come around and fix it.
I am the same person as the OP. Just realized this is a different account.
well like any used vehicle.. check the tail pipe for signs of oil seeping past rings and valve seals... listen... hard at how much noise the engine emits - piston slap - rod or main knocks.. on start-up, when it is cold and warmed up.. check the radiator for coolant.. and bubbles... on and on.. low oil pressure might be a red flag and might not be.. you have to look and listen..
Good plan.  This vehicle has good mileage for its age but it is still a well used vehicle with aging parts. Plan for potentially costly repairs and make sure the purchase price makes such repairs tolerable.  No matter how carefully you scrutinize a vehicle, new or used, it can still give you unwanted surprises.
We had a Tahoe at work that had low oil pressure.  It would have random AFM issues as well and the recommendation was a new engine.  I would stay away from this one.
Well after talking with the dealer some more yesterday they have agreed to put a new oil pressure sensor on the vehicle and see if that resolves the issue. They stated they would not be going any further than that however. After talking to a couple of mechanics and reading up on the symptoms typically seen with a faulty oil pressure sensor I'm not optimistic this will fix it. We did take it to a 3rd party mechanic but he said it would be $150 to do the test with a manual gauge so we decided against that when the dealer should be handling it.
Looks like we will end up having to walk away. A real shame because for a 2007 this vehicle was super clean and everything appeared to be in excellent condition other than that. Oh well the search continues I guess.
Edited by 03pewterZ
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
