M
Need help. I have a 2015 6.2 that's throwing a Po307 code. Misfire on #7.swapped out the coil, spark plug, and wire with cyl.3. Erased code on startup immediately set code again. Any thoughts on what's next. BTW it does have 103000 miles on the clock.  TIA
My bet is a lifter. Been there done that unfortunately.
Had the same thing on my L86 at 125K miles.  Miss on number 7 it was a bad lifter.  Now I have a stage 2 TSP cam and DOD delete because of it.:thumbs::driving:
I also had a miss on #5 at 115K miles.  That was a broken valve spring but It didn't drop the valve so it was a cheap and easy fix.
Don't drive it anymore and pull the valve cover off of the drivers side NOW.  It's easy to do.  Lets know if you have any questions about it.
Thanks again for all your help. I'll get it in the shop tomorrow and pull the valve cover. I'll let you know what I find.
Did you do any misfire tracking leading up to this, or was it basically hard fault stored and now you are looking into it?
Thanks
i had a misfire code on a 12 siverado a 14 taho and a 19 tahoe and all three were an electrical issue .. bad pin connector or green crusty broken wires in the injector or coil harness
Sorry for the long delay. Shop has been closed for the last 3 days. I'll check later today to see if he has found anything.
Finally got a answer. Broken push rod. #7 exhaust. Will replace push rod and lifters.  No damage to the piston or valve. Thanks again for the help!
    Tbhats2130
    Tbhats2130
  • Who's Online   5 Members, 0 Anonymous, 720 Guests (See full list)
