That's crazy, almost reminds me of a runaway diesel.
I'd definitely bring that in
I showed the video to the mechanic at the dealership, its going in today.
Here is the dealership technicians report: Nov 25 - Scan, no ECM codes stored and no bulletins apply. Codes U0140, U0131, U0151, U0102 and U0146 are set history in the BSCM which is related to bulletin 20-NA-155. A new BSCM cal is available to correct condition. Called TAC, no help. Removed the induction pipe at the throttle body, no sign of moisture or anything that would affect the throttle blade. The accelerator pedal is free of obstacles and does not appear to have anything that could hold it down. Parked truck outside over night. Next morning, Nov 26 - install the scan tool, monitor the induction data list and start. The engine RM flared up to 1850 then quickly down o a normal cold idle. The impression I got was an engine start with an incorrect idle learn. Found the idle compensation at 67% which seems high for a vehicle with 12K mileage. Inspect throttle body, completely clean. Correction: No repair possible today and no problem was found. I did install the latest BSCM cal, prog code 28YN51521209 for customer satisfaction and just in case it's related. Wipe down throttle body and perform an idle compensation relearn. Run and clear codes. The engine started without the flair this time. Customer to retry.
I will give it some time and see if it happens again and post if it happens again....or not.
Edited by Denny NWO
On 11/26/2020 at 9:03 AM, mafd2 said:
Can you post the video on youtube and add the link here?
Wow!  Unbelievable... As said above it's like a runaway Detroit diesel from years back. I hope it gets figured out. Keep us updated and thanks for posting the video.
Been around one or two... even had  a deuce n a half that had been messed with run away on me
For those that haven't seen what happens
I went to work today and after 10 hours of sitting outside in 20F cold, it started and fluttered and flared up to about 2000 RPM for 2 seconds then ack to idle and bounced up and down a bit. I never took my foot off the brake and did not touch the throttle. Video is noisy at the end as an aircraft was flying over on approach to the airport and I shut the drivers door. Guess the BSCM update didn't do much.
Edited by Denny NWO
Subscribing because mine just did something strange to me today, not what yours is doing though, but right after startup during the gauge sweep it sounded like it reved up to 1500-2000 or so, then right back to idle. it wasn't cold though, maybe 5c, in the garage. it was the second start but still cold. I was just moving it around to put the winter tires on it, a couple months too late! I'm not going to worry about it unless it happens again, but I'd like to hear what your final resolution was.
speaking of all of this, not that this situation seems likely to cause a runaway, but does anyone know how to do an emergency shutdown on this truck? this is something that I think keyless start systems need to get standardized on. I had a Ford once where you could do an emergency shutdown by holding the button for about a second. annoyingly it would only restart in park, it would not restart in neutral. I have had 2 FCA cars which as far as I can tell have no way to do an emergency shutdown at all, which is honestly rather scary. What would you do if you had a sudden coolant leak? or an loss of oil pressure? or a fuel line comes loose and you've got flames shooting out from under the hood...and the only way to stop the fuel pump from pouring fuel onto the fire is to get from your 85mph interstate speed to a complete stop to get the transmission in park before it will allow you to shut off the engine? especially with vehicles that have EPAS now (electric power assisted steering) and knowing that the vacuum in the brake booster will still give you one or two brake applications with power assist before you turn out of boost, it would seem that being able to shut down the fuel supply from the fireball under your hood is way more important for your safety than preventing engine from being able to turn off while in motion.
It did a slight flare on the post from Sunday but on Monday, it went to 3500RPM for almost 8 seconds. Tuesday it started normal and Wednesday (tonight) it sputtered on start up and only slightly flared up. Every time this happens, it has been sitting outside for 8-10 hours after finishing work in temperatures just below freezing. It never does it in the morning at home parked in my heated garage. Here is Monday's start up. I have my foot on the brake the entire time and lift it at the end. It going back to the dealership tomorrow.
The Start/Stop button will shut the engine down. One time when the RPM took off to park redline (3500RPM), I just hit the start/stop button and it shut down immediately. I waited a few seconds and hit the start button and the engine started normally.
So it went to the dealer a second time and they flashed a new BSCM calibration and it started fine until yesterday and it did its random start and redline. Tonight it fired and stalled then the starter cranked for 7 more seconds and it fired and redlined and held until i kicked the throttle pedal. It's going back to the dealer for a third time and they will keep it until they figure out the problem.
2019 AT4 Cold Start High RPM after long crank.mov
Edited by Denny NWO
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
