16 hours ago, wewhit said:
I had one of these installed on my lowered '19 High Country and it made a huge difference in body roll.  I traded that truck for a '21 High Country 3.0 Diesel with Adaptive Ride Control and plan to install one on this truck as well.  I am glad to see that it worked well on ARC trucks, too!
Although this sway bar was a litter pricier than most, it was the best upgrade I have done so far and well worth the money. You will notice the improvement immediately and enjoy driving your truck even more. I recall being a little disappointed with the amount body roll it had when I first bought my truck but now it corners so much better. Enjoy your upgrade.
I decided to install the Hellwig 7781 front sway bar as well on my 2021 Silverado 1500 Crew Cab Short Bed.  Not as big as an improvement compared to adding the rear sway bar, but still very significant.  Since it's cheaper that makes it a worthwhile investment.  Also much easier to install since there already is a sway bar there.
Now you can really tell the all-terrain tires are the weak link.
Rear sway bars make a big difference when towing a trailer or hauling heavy loads in the bed of your truck.  My F250 has the "camper package" which includes stiffer springs and a factory installed rear sway bar and it is a night and day difference when towing a trailer or carrying a heavy load in the bed.  The truck rides flat and true through the turns and doesn't give you that "oh ******" feeling you would normally get when you turn and it feels like an ocean liner about to tip over. :)
I'm glad to hear the sway bar additions have worked for y'all, but I am curious since my 2020 Z71 has never felt like it leaned much in the turns.  My aftermarket springs and shocks may have removed most of the sway and I just don't remember, who knows, but I'm glad y'all have found solutions to your issues.   For you sport truck enthusiast, I'd be curious to know what the results would show on a figure 8 test pad.
Edited by Gangly
Exactly.  You can run stiffer springs and shocks to control body roll at the expense of ride quality.  My Silverado 2500 HD had very little body roll because it was sprung for heavy loads.  My Silverado 1500 with softer springs and upgraded sway bars has very little body roll now too, and it rides much better than my Silverado 2500 HD.
Is the sway only an issue on the trucks with the adaptive ride control? I have not noticed it much in mine, I mean it doesn't handle like my old Grand cherokee but its a truck....Mine is the 6.2 with max tow so mine might already sprung a little stiffer
If you are satisfied with your existing amount of sway, you may not want an aftermarket sway bar. Your driving style may not require it either.
My truck has the ARC and Max Tow Package. My ride comfort didn’t change and it doesn’t seem to compromise the ARC system at all. I feel the rear sway bar made an improvement that was most noticeable for the investment. It added more confidence in cornering and evasive maneuvers if necessary.  On and off ramps are easier at normal speeds because there is less leaning going on.
If you do decide to go with a sway bar, take note that there are two different kits. One for the standard height trucks and another for the higher AT4s with the 2” lift.
For uh educational purposes.....I pushed it in to a couple cloverleaf on/offramps and 40-42 is about all i can do comfortably the back still feels reasonably planted but I could be on the edge of traction I am not in the habit of pushing it in the truck so I don't have a great feel for it, however  there is allot of body roll toward the front driver wheel.
Yes, the rear sway bar prevents a lot of that front end dip and body roll around the ramps and it makes it seem like all four tires are planted more equally. I only added the rear Hellwig and there's a factory bar already on the front. Traction still feels balanced, no noticeable oversteer or understeer around a quick corner under acceleration.
Is this something the dealer could install?  I’m concerned that if things need taken apart to get this installed, they might not be put back correctly and I’d rather deal with the dealer.
Also, assuming it’s a no go at the dealer, is there any concern that this will void any part of the warranty, like the ARC?  That would be too expensive to risk.
I’m with you though, this thing (Denali) is a boat around the curves and sport mode doesn’t help.
I don't think a dealer will touch it because it is not an accessory provided by GM or dealerships.
I installed it myself and I don't recall having to take anything apart during the install. You just mount the hardware to the vehicle in certain locations.
So far I can't see any reason a sway bar could be detrimental to the ARC or would void your warranty. GM chose not to include a rear sway bar on their 1500 trucks (probably to save cost) but I notice that all of the recent Tahoes come with rear sway bars. I had a 2017 and a 2020 Tahoe with factory rear sway bars and both of them handled corners with a lot less sway much better than my brand new 2020 Sierra Denali before I added the Hellwig to the rear.
  • Thanks 1
  • 1 month later...
If I plan on getting a 6 inch bds lift kit and 35 inch tires, would I still need this sway bar? Or would the lift not allow it?
The sway bar is not required on any vehicles. It's up to your preference on how it feels and handles with your setup.  Hellwig's website shows that they have a rear sway bar that will support lifts from 2"-4".
REAR SWAY BAR KIT2019-2020 GM SILVERADO/SIERRA PICKUP W/ 2-4" LIFT
Part Number: 7844
You may have to contact them to see if they have any additional hardware that supports the 6" lift.
I have an Cognito 1" lift block on the rear leaf springs as well as the Air Lift system on my 2020 GMC Sierra 2500HD Denali.  Would this be compatible with these installations?
Thanks!
Edited by Laurent Kim
Thanks!
There's a different model (7782) for the HD trucks and it is a lot more expensive for that rear sway bar.
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
