Does the info system in my GMS sierra set a default music app to load every time at every start? iheart radio app will start every time i start my truck no matter if i was listening to another source or not when i shut the truck off and its always the same station that i did not select. I can't figure out how to stop this from loading at start. Sometimes iheart and Sirius will play at the same time. I do use appleplay, not sure if that has something to do with it or not. Any suggestion to correct would be great.
I wish i knew how to fix this as well. My iTunes music starts up everytime. Only if I make sure the trucks radio was on before I shut it off then it will not play it upon next start up. It’s only one extra step but annoying.
Does your vehicle have a driver profile set up which also stores your preferences in the cloud? "The information that goes to the Cloud. This includes most of your embedded Navigation settings (if equipped) and audio settings, including your Favorites." This allows you to set up your profile in another GM vehicle you own. You can also try switching the profile to "Guest" to see if it makes any difference. Let us know if you have any luck with this.
https://my.gmc.com/how-to-support/entertainment-connections/displays-radio/driver-preferences
