Hey guys, Got a 2019 Z71, bought new with 12K miles on it.
Ever since new, it sounds like the front drivers wheel when hitting a bump at lower speed(around 15-30 mph) is almost bouncing, like a bad strut/shock/bushing. Had it checked thoroughly by dealer twice, everything seems tight. Had an alignment done too.
Seems also to be noticeable at winter time(40 degrees or colder). Didnt notice much this summer, also dont notice at all at highway speeds.
Anyone experience this or have a thought? Dealer is willing to replace strut but that doesn't seem to make sense either. I have even watched it out the window, and tire shows no sign of bouncing.
I have a similar noise going through a dip when the truck is coming back up. Sounds like a knock/bump and can actually be felt in the floorboard.
I can hear it if I bounce the truck on that side too.
I’m gonna try to take it in this week.
That exactly it! seen nothing wrong and my buddy is a 20 year certified gm tech, he is who works on these and my personal truck, and even he is stumped. ALso hard to duplicate problem
Let me know what you find if anything.
Tell them to pull down on the fender to bounce that corner. I can replicate it fairly easily once the truck starts moving enough.
Had the same issue a while back. Easies way to replicate it is drive over a piece of lumber 4x4 or sometimes 2x4.
And yes my dealer gave up on it so did I but in a stroke of luck its gone. I think what ever was the issue it rattled its way out and fill of the pickup for good. Either way can't hear it anymore
What did you find out? what do you mean by pull down on the fender, are you saying the fender is loose or hitting while hitting a bump?
Haven’t had a chance to take it in yet. Maybe this week?
No I mean to pull the whole truck down to bounce the suspension. Pop the hood, put 2 hands on the fender (from the side you’re hearing the noise) and pull down repeatedly to bounce it. (Seeing as how everything is plastic on the front bumper I felt this was the easiest/safest way)
When I say “pull down” I mean with your whole body weight. Get that sucker moving!
Okay i will try that. IS what you were hearing considered normal just bouncing or noise feeding thru the fenders? Or did you find something wrong?
 I had a similar noise from the front passenger side, and would hear it when going over bumps, railroads, etc.    The sound started around 15,000 miles and I just tried to ignore it for the next 5,000 miles, but luckily it disappeared completely when I upgraded the shocks.
Definitely not normal. Based on my unscientific “put your finger on the part to feel the noise” experiment it’s coming from the shock. I’m guessing inside.
The left side is silent.
I tried bouncing it, might not be moving it enough as i am not the biggest guy, but it sounded fine. However, another mentioned drive slowly over 2x4 and that duplicates it. Passsenger side is silent
Curious, do you guys have z71 suspension with same white ranchero shocks, wonder if some are bad. Sounds like it isnt acting properly at low speed, probably a internal valve issue.
My tech said bring it in, we are going to try shock and see if it improves/or stays the same. Either way, it is one more thing out of the way
PS: i wonder if these damn trucks are too light, With all the plastic and aluminum, i notice the sound is bettter when the truck has cab full and it is warm outside
Tried this, it does make the sound. THose horizontal cracks in pavement do it too.
How many miles did you notice it took to go away? I only have 12k on it, might need to break in more, shocks could just be darn stiff
Alkaspeltzer,
I HIGHLY doubt it will go away since its most likely a blown shock.  I've had to replace many over the years on various vehicles for various issues similar to what you describe.  I just replaced my white Ranchos in my 2020 Z71 for the very same thing and when I pulled out my passenger side shock I readily identified a small leak that appeared to have been present for a while.  Is it normal for a shock to wear out, yes, is it normal at that low of mileage, no, but it does happen and with a prior owner who knows what he put the truck through.
Mine started clunking and making weird noises pretty bad around 15k miles, but it would occasionally clunk long before that, my guess would be around the 10-12k mark.
If the dealership is willing to replace the shock, let them, that seems the obvious route to me.  If that doesn't solve the problem them its something bigger and the dealer needs to address it under warranty anyways.  Regardless, step one would be to replace the shock and if they are willing to do it, let them.
Also, with a deteriorating shock, there is a good likelihood you wont see wheel bounce.  Most of the sound is coming from internal components as a result of damaged components or loss of dampening fluid.
Either way its a minor thing, don't worry, it will all get resolved shortly.  Good Luck!
Edited by Gangly
About 20k miles or so
Just wanted to give an update. I did get the dealer to agree to shock replacement.
Clearly it was blow. When we removed, it was not as smooth as the other side and had little resistance. We actaully knowing it was failed pushed it back past the seal, and it barely had any pressure. In fact, all the oil was mixed with air/water where with the nitrogen charge, that shouldnt happen as much.
Been a couple weeks. Definitely quiet and rides like a z71. Took the bounce and lightness i was feeling out of the truck. Love this thing now.
Thank for all the support!
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
