I was unloading my truck, I had the exterior lights turned on since it was dark.  On the third trip back to my truck, I saw the rear tail lights flashing on one side then the other.
What is this,  is it some warning?
My 2021 3500 is doing the same thing. Following replies. Taking to dealer this week. 430 miles, started night I brought it home. please let me know if you have a solution.
You mentioned you were unloading with your lights on, was the truck running or not running when this happened?
are your tire pressures low?
I just learned that if you have a low tire pressure, the turn signal light in the same location as the low tire will flash
it will?  That is going to be confusing as hell to the owners, unless it's in the owners manual and they read their manuals carefully.
that is what I heard, not sure though
The guy with the funky DIC went to the dealer and they pulled a couple fuses out and put them back in. Fixed his issues.
This is true. When the truck is in park, a blinker will flash on whatever corner your tire is low. I've seen it when I aired down to drive on a beach, very confused at first.
Sent from my SM-G981V using Tapatalk
Well that is a neat idea!  Maybe.  Credit for the creativity of whatever engineer or individual thought this up!
my situation is this
I rotated my tires and the computer sees the front wheel is on the  front not the back where i put it
I run 60 front 80 rear
Low tire monitor is on
lights flash and horn beeps when i turn off the truck
quite annoying when i go somewhere and people think i am beeping at them
I don't want to go to the dealer every time i rotate my tires
i did pump up the tires to 65 and everything works as it should except when you look at pressure in information center shows
the front wheel pressure is the opposite of what it is
You have to relearn the TPMS position of the tires every time you rotate. The sensors don't just automatically know where they are on the truck.
https://www.amazon.com/FASLINK-Relearn-Vehicle-Universal-Pressure/dp/B08GSH84D9/ref=sr_1_1_sspa?dchild=1&keywords=TPMS+Reset+Tool&qid=1611146186&sr=8-1-spons&psc=1&smid=A38C5MVY781YQT&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyM0tGVlk1TklMNFkwJmVuY3J5cHRlZElkPUEwNDI0OTkxMjRRWURMRzg2RVY0NiZlbmNyeXB0ZWRBZElkPUEwMjY3NjM2Mjg5N1FITkJQVDFLVCZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
    Rockboss
    Rockboss
  • Who's Online   4 Members, 1 Anonymous, 626 Guests (See full list)
