Hello I am new to the Forum but I currently have a 2020 2500hd with the duramax. It is my third diesel and the 2020 seems to have a much lower operating temp according to the gauge. It fluctuates between 170-185 Approximately. The previous 2016 I had was very consistent running just below 210. I have asked dealer if it’s normal operating temp? Gauge issue? I am only concerned to make sure engine is at proper temp for emissions etc. any info would be great thanks
This is typical of mine.  About 40F and not towing.  Goes up a smidge with the trailer.
Edited by XY74
I suspect these gauges are rough approximations rather than finely calibrate instruments.
Mine says 210 on the dash but the reading over obd2 with torque reads about 184 when the dash says 210 so the gauge on the dash is probably a dummy gauge.
Sent from my ONEPLUS A6013 using Tapatalk
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
