Got a 21 AT4 a few Months ago and the apple car play constantly skips like a scratched CD while listening to music. I’ve tried everything I can think of. Anyone experience this and figure it out?
Mine does the same thing. It's also been in the dealer for 3 weeks now after they blew out the master cylinder installing the Brembo Front Brake Upgrade. There seems to be a problem on GM's end with the programming. Anyway, I've been in 2 different rentals, a Buick Encore and GMC Acadia and both skip like crazy either while streaming music or while on a call.
That’s real handy. I’ve tried even plugging the phone in and still can’t get it resolved. I just want to listen to music!
I have a 2019 Silverado and I use Apple Car Play quite a lot on long drives.  I have noticed that after about playing for 2-3 hours it will produce static that is corrected by unplugging the phone and re-plugging it in.  I have never figured it out.  I use the original apple cord and it has happened on both the USB and the USB-C ports, same phone and different phone.
Just picked up my 2021 AT4 and I have the same issue.  I am also having another issue with the infotainment system that apparently is fixed in TSB #20-NA-221 maybe it will address this issue along with the issue of the APPS application not working.
What’s the other issue you’re having? The skipping is killing me. I dread bringing it to the dealer as I know it’s gonna be a headache.
I am having the exact issue that is explained in TSB# 20-NA-2231, you can find it in this forum.  The problem with these new vehicles is there is some much technology I feel that mechanics just can't keep up or understand everything that goes on, and especially when everything is software managed.  This is by no means any disrespect for the mechanics out there, it is just that software developers sit in their own world, a perfect world, and when the software gets rolled out things change.  I just wish there was a way to contact the manufactures directly to share these issues with so that they can get the issues directly from the users.  Enough ranting I hope that this TSB fixes the current issue fo the apps not loading but I hope there is more in the fix that corrects this skipping issue as well.
So on my 16 AT my android phone was flawless for years with Bluetooth,  switched to apple and BAM! Random Skipping/cutting out on Bluetooth and car play.  Just got a 21 RST, have done some of the car play and 0 issues
Just got mine updated with TSB #20-NA-221 and life is good.  Skipping is gone, apps are working.  GM Tech told me that there were a number of things this fixed, even some issue with touch screen calibration.
V153 which was prematurely announced but as of last night is still not available should fix this. The update above is just calibrations to fix the back end connection; V153 should be available shortly.
Edited by GTPprix
I was getting this in my 21 SLT. Then read on a forum that having an Apple Watch or some other sort of smart watch could be the cause. I disconnected the Bluetooth on my Garmin smart watch and it hasn’t happened again. So I’m guessing that it’s somehow related to the phone/bluetooth
Just picked up a 21 Trailboss and wouldnt you know.. skipping after connecting phone.. Thx for the tread
Hoping to find a sure fix on this at some point so I don’t have to goto the dealer 100 times.
Is this something that Downloads somehow or does the dealer have to do it ?
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
