Another intake question ? Looking into getting an intake for my 2020 6.2l Silverado and I’ve narrowed it down to the S&B intake, the Roto-Fab, and the Cold Air Inductions intakes. All different prices and slightly different designs so I’m just curious to what most people are running and which one is “the best” thanks for the help.
I know most ppl are probably running Rotofab and I’ve used their systems before but the other two intakes being lower priced and still looking good has me curious
There's a lot of positive reviews for S&B on this Forum and from other 6.2 drivers I've spoken to. That was enough to persuade me to order mine this morning. They say their current back order is 2-3 weeks. Rotofab gets excellent reviews as well. I believe the Cold Air Inductions unit utilizes the factory bottom end of the box. The design doesn't promote increased air flow as much as the other two.
I went with the RotoFab and I'm very pleased with it, great growl under the hood, performance feels great and IMO is one of the best looking units!
I had an S&B on my 2012 F150 EcoBoost and it was good quality also, but after finding out it was on back order for over a month I went RotoFab, no regrets whatsoever!!
Edited by Spyderwebb
It does look like the S&B has the highest airflow design with those ports on the side that pull air from the fender area as well. I will admit tho that the Rotofab does look the cleanest. The GM intake looks like ?
I have been researching this for a while. From what I found the S&B is probably one of the best and Rotofab a close second. Basically it will come down to which one you like as far as looks and availability.
Have you found any numbers from the s&b? I like their design but haven’t seen any numbers front them.
I bought the S&B because it has more air flow, had previous one on my 2018 and loved it!  No issues whatsoever. And for $330 you can’t beat it.
The RotoFab looks really good under the hood but when I checked it was close to $500. That’s around $170 more for something that doesn’t flow as well as the S&B.
In my opinion either one is worth the money though and you can’t go wrong.   I just have experience with one than the other.
They don’t post HP/TQ numbers.  They post air flow. And they are the highest out of the CAI’s.
Yeah, I think its like 51.7% more than stock.  Just reading and watching tons of stuff. I also like how there are more than one suction points (2 or 3 depending if you put a blanking plate on.  The filter Is almost the size of a 5 gallon bucket.
Roto fab does look nice but I’d be curios what filter they use,  wonder if it’s an s&b? Lots of intakes use an s&b filter
Agreed. I looked at these because I have some GM points saved up and the ECM reflash sounds cool. But I really, really hate the design on the clear cover. No bueno.
I went with the S&B and it is great.  Exceptional quality. Filter is huge.  I also installed the filter cover/bag. Have not had any problems with it and have done 14000km since I installed it.  No error codes etc.  The big thing is to disconnect the battery before you start the installation and leave it disconnected for at least two hours after you have reconnected the mass air flow sensor (MAFS) in its new position.  When you reconnect the  battery and run the vehicle the computer does what it needs to and you will not get error sensors related to the MAFS
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
