Had anyone tried to make the fogs turn on automatically when the headlights turn on?.  There was a write up on here for my nnbs where you added a wire and resistor I believe as a jumper from relay to relay in the fuse box. Essentially making it so that when the headlights relay was activated it would jump and power the fog relay. I installed the hack and it worked absolutely flawlessly for 12 years before I sold my nnbs. It removed me having to hit a fog button on the dash every single time. In my opinion it looks better with fogs on.
I also just ordered the harness from Boost.  It should arrive late this week and I hope to install it next weekend.
Easy, cheap, quick and no wire taps.
I just installed my Boost Fog Light modification and it takes about 10 minutes.  Hardest part is separating the wires for the tap.  I also called Boost and they told me since my vehicle has the Auto High Beam feature, I will retain this feature and my foglight will remain on too.  If I recall it was like $20 and money well spent.
    overspeed
    overspeed
  • Who's Online   3 Members, 0 Anonymous, 1,015 Guests (See full list)
