My front differential is looking like it will need a rebuild sooner rather than later. I've done some preliminary research and it appears that there's an Eaton Truetrac (912A557) compatible with this application. Keeping in mind that I live in Alaska and the roads are covered in snow/ice for about half the year, is it worth the trouble?
  • I live in the south west and get virtually no snow or ice, but when something needs changed it needs changed.  You can google search easy enough the advantages of what you are looking for.  What it would come down to me is what I am willing to do for my truck.  If money or time isnt an issue, why not?  I liken the type of question to do I run stock lift or put in a 2 ".  It really is about preference and in most cases the performance benefits are not so great as to justify the means, but sometimes looks better.
Nope, your front differential is an 8.25" and there is no limited slip or locker made for them since I last looked a few years ago.  Most writin' says the case cannot take the strain of one.
Well bummer. Thanks though
James stole my thunder. When I was installing a air-actuated Ox Locker in the rear end of my '07 Silverado, I looked into getting one later on down the road for the front. As I looked, I noticed nothing was available - not from Ox, or anyone else that I could find. There were listings for EVERYTHING but. The general consensus out there on the net is that these are the weakest geartrain assemblies ever produced.
I had thought this only pertained to 2007 and newer trucks, but I guess not. That sucks.
  • 3 years later...
Alright need some advice here please.. i had ordered the wrong diff for my 1500 Silverado non HD which i ended up ordering instead one for an HD.but the gear ratio is the same for the front of my truck and it's 4x4 will i be able to use is still or do i need to get one for a non hd.. i heard from a friend it would work but would like an second opinion and will i run into any problems in the future if it turns out i may use it?? I do know the housing is a slite bigger.. so that being said what should I do.. 🙏🙏
You need to get a regular half ton diff.
Not only are the mounting points different on a half ton frame compared to a 3/4 or 1 ton frame but the driveshafts are different sizes and the stub shafts are different too for the bigger axles.
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
