I didn't know they had options. I don't ride around with my ball in, just take the 30 seconds to install it and lock it in when needed. Im interested to see the responses though.
Sent from my SM-N986U using Tapatalk
Look up B&W trailer hitches...
Nice design, a bit rich for my blood. If you tow a few times a week I could see it being a good investment and saving you $1500 plus to replace these tailgates [emoji106]
This is true. However, the big benefit of the B&W is you basically have an assortment of drops/rises with an assortment of ball sizes without needing all the storage space for them. And you don’t have to remove it (if you buy the right one).
I had a Curt tailgate sensor installed on my truck so the gate won't drop when a hitch is in the receiver.
Edited by elcamino
Never saw that before. Neat. Makes you wonder why GM didn’t think of that...
Its new,  even the local Curt dealer was unaware of it....My brother, lives in Cleveland (Wis), found a Curt dealer in Green Bay who installed one on his GMC so I sought out a local dealer.  But it looks like an easy install, took <30 min. When I looked online it said back-ordered but I see that's no longer the case.
Edited by elcamino
I read about it, but personally wouldn’t want it or trust it. If sensor fails for any reason,  there goes the tailgate. Jmo
Edited by Dogdad
Spelling
They didn't need to.  Curt and GM partner together so this is offered through every GM dealership as an accessory.
GM Part# 19421060
GM Part# 19421060
I recall seeing that but never read through the description as it said it was a hitch cover.
Just saying, they could have embedded the same switch in the hitch itself from factory. Would be a lot cleaner.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
