I have a 2020 3500HD Duramax with the 5th wheel prep, 6'9" box. Just wondering what you guys are doing with installing a hitch. I have an existing Husky 16k 5th wheel that is in a 2007 Duramax, and was looking to just get the puck adapter through Husky but they don't make one for our model years yet. I have yet to speak to Curt but was wondering on what you guys were doing.
Thanks!
Andersen Ultimate Hitch connected to a gooseball in the OEM puck hole. 40lbs light and drives like a dream (no clunks like my Superglide used to do). Adds clearance from the cab as well depending on how you configure it.
Hello,
I replaced my pin box with the Reese Goosebox so that I could keep the bed of my truck clear and switch to a goose neck system.  The Goosebox does not void the warranty on my 5th wheel frame, and it was a very easy install.  I was coming from an older 5th wheel hitch and would have had to upgrade it anyway, so the cost was essentially a wash for me.  Again, the added benefit of not having to lift out a heavy hitch and keep the bed of the truck open 100% of the time made it a no brainer for me.
Same here.  I really like this setup.  Since you have the short bed this will buy you another 5" clearance or so around the cab for tight turns too.
On 3/26/2021 at 2:43 PM, cdnSpinalTap said:
Hello,
On 3/26/2021 at 3:44 PM, Steven Smiley said:
Reese Goosebox here! Been using on Brother in Laws Ram Dually. Trying on my 3500 Denali SRW Standard Bed tomorrow. Stay tuned
The Reese GooseBox will be a good choice for what you want. Minimal effort taking a ball out of the bed for complete bed use. Also, you retain your trailer's frame warranty in the event something happens related to the connection. I've been using this setup for a while and it's very smooth with little bouncing or chucking.
    Daniel422
    Daniel422
  • Who's Online   5 Members, 1 Anonymous, 1,836 Guests (See full list)
    • It is a company truck. Not under warranty. Both companies I’m involved with usually buy trucks that are discounted when looking. Except what the owners drive. Being retired and minority owner. I don’t drive a company truck. If they have the new GM gas engine it would be in a service truck.
    • Update!   Had the dealer look at the issue. First tech says no problem?? I said there was no voltage on the brake terminal on the 7 pin connector! He said he did not know what pin I was talking about. So they bring out a seasoned tech and I explain to him. He attaches a VOM and has me push the brake, and sees no voltage!!    Tom, the seasoned guy says lets go back to my service bay and look closer. We discover thru his on line system that the controller is a "smart controller" as it needs to detect a trailer connected before the brake voltage is allowed to the 7 pin connector!!! He also showed me a GM bulletin stating some trailers with LED lights have such low resistance the controller wont recognize them!!! I was thinking WTF, but thanked him for bringing me back into the service bay and explaining this all to me. He also plugged in a trailer simulator and it showed the brake controller was indeed working.   After my dealership visit I hooked up to an older camper with standard 1157 lights and the truck did connect and the electric brakes worked great!    Not to sure what I have to do with the equipment trailer with LED lights, I cant tow it with no brakes.   Why did something so simple for many years have to get so complicated!
    • Do find out as that would be interesting if they have been using any L8T engines or for that matter have been running any of the Ford gas 7.3 to see how they have been panning out.    I assume your nephews engine replacement was on his dime as the regular warranty would have long past unless he had some form of extended warranty that covered such events. That shows though and may depend on the year of the build that failures are occurring with the valve train well beyond the warranty distance and more than likely so will others have that sneak up on them.
    • I realize this is an old post and its probably been talked about since then on this forum and I may have mentioned it myself but the Chev multi flex tailgate on the HD trucks are all aluminum so there is that one item that I am aware of on a current GM HD truck that is aluminum but if its the standard tailgate then its still a steel unit as far as I am aware to current 2026 model year.
    • I am surprised it didn't pop back up some just in time for the end of school/summer holidays and July 4th time period. Here in Alberta it hit its low coming off the high back a week before the end of June or so and has been creeping back up some and would equate roughly to around 20 cents per gallon increase. Of course there are various factors and one is the games they typically play with wanting to capture that holiday vehicle movement but also our government directly causing our Canadian dollar to drop ( a polite way of explaining the real picture ) causing our prices to go up rather than continue down like it should have, and even though we are sitting on the crude.
