So I've recently joined the club of leaking rear windows on my 2019 Trailboss LT. I'm at 35600 miles as of today and will be dropping my truck off on Tuesday to start the grueling process of re-sealing...window replacement...repeat. I've read the lengthy post on the leaking rear window and realize this issue will never fully go away. My concern is that I'm almost out of my warranty and will likely only get the re-sealing step of the TSB completed before I'm over the miles. Thus, I would be paying for the eventual window replacement out of my own pocket. My truck is still in great condition other than a lot of miles and some water marks on the headliner from the window leak (no mildew smell). I absolutely love everything else about the truck. My thought is to trade in my current truck for the 2021 version of my exact truck. I know the leak is still an issue but doesn't seem nearly as prevalent as it is in the 2019's... I'm open to any thoughts/suggestions/recommendations. Hoping for some guidance please!
Edited by mj715
caps
I think you could make the switch work out pretty well in your favor. Trade-in values are great but of course the downside is that inventory is pretty tight.
You’ll get the 10 speed instead of the 8 which in itself is a great upgrade. As far as the window...the 2021 has at least less of a chance to leak. You see the thread and know there aren’t any guarantees, even for a 2021. But the odds are better than with a 19.
I’d prob just have a solid window installed by a reputable glass shop on your 19.
GM wins for their poor engineering.  You bought 2 trucks when you should really only should need to have purchased 1.
This.... why would you buy another that'll more than likely have the same issue?
Unless you find a killer trade in deal with the inventory levels being short keep what you have. Just put a solid window in and forget about the leak altogether. You seem happy with the truck otherwise.
I've never understood why people buy a truck to replace a window. I buy a truck to replace a truck. Is the truck broken? If not, don't replace it. If the window doesn't work, fix it. K.I.S.S.
Just saying, people today are getting back what they paid for their trucks two years earlier. If the numbers work, getting one that’s newer with no miles, a ten speed, and a full warranty...less likely to leak...worth looking into. Personally, I would trust my 19 out of warranty about as far as I could push it.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
    • The average lifespan of automobiles on the road is increasing - here's why
