The search function doesn't turn up much for re-gearing a T1... Are there options yet for us? It like to bump up from the 3.23 my 3.0 has before I get bigger tires.
From what I understand, the front is welded, and thus the whole assembly needs to be swapped, had anyone done this? Where the cheapest place I can get the parts? What about lockers, am I SOL for the front end?
The front end probably doesn't have a locker available for it.  Wouldn't be very street friendly either.
The 9.5" 12 bolt rear is a variant of the old GM 9.5" 14 bolt Semi Floater so it can be regeared with earlier generation parts and use their lockers.  This has been done before.
Copy that. I guess to clarify; I'm trying to figure out if there are any vendors selling re gear Kits for the front end. So far it looks like I'll need to buy a whole new front diff assembly to do a re gear.
The more gears the transmission has the less the rear end gears matter. Those 10 speeds don't really need gears if you stepping up to 33's or larger. Plenty of guys are running 35's no problem.
How will you tune it for the gears?
It's not like the old days where we had 4 speed auto's and putting 35's on a 3.42 gear truck turned it into a 3.08 geared truck that couldn't even get out of it's own way.
I’d bet you could swap axles with a 3.42 geared truck to get a bit lower.
Ditto on the new transmissions. Ever since the 6 speed they’re super low geared and pull hard, even with higher axle ratios than traditionally.
At any rate the front diff can for sure be taken apart and serviced. So at the very least right now there will be GM axle sets available. 3.23, 3.42, and…3.73?  What’s the gear ratio on the 3.0L with the towing package?
Mine has the 3.23 in it. I mainly want to get back some of the lost mpgs from the tire upsize. When I regeared my tundra for 35s I went from 13 to 16 mpg. Some folks don't care about mpg but I bought this thing in September and have 30k on it already so it kinda adds up fo me.
If I were you I wouldn't regear, think of it this way the money you put out for a regear lets say $2000.00 and you pick up 2mpg it will take you years to recoop that money put out for gears to pick up 2-3 mpg. How did you get your mpg with the bigger tires? If you used the odometer and you have bigger tires your mpg calculation will be off because your recording less miles driven cause our speedometer is off.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
    • Last three days, 12.75". Yesterday, 6" of it in under 2 hours. Lawn loved it, basement not so much. 😏
