Chevrolet and GMC Dealers:
As promised, we want to continue to keep you in the loop regarding the global, industry-wide shortage of semiconductors.  Due to these shortages, we are announcing the following change to certain vehicles:
HD Radio will no longer be available on certain 2021 model year:
  • Chevrolet Silverado 1500
  • GMC Sierra 1500
And all 2022 model year:
  • Chevrolet Silverado 2500/3500 HD
  • GMC Sierra 2500/3500 HD
This change takes effect starting with vehicles schedule for production on or after July 12, 2021.
For orders with a scheduled production date on or after July 12, 2021, GM will build certain 2021 light-duty and all 2022 heavy-duty pickups with the added RPO code RG0 - Not Equipped with HD Radio (refer to the updated Order Guide and table below for trim details). This RPO code will be reflected on the Dealer Invoice along with an associated $50 MSRP credit only for affected 2021 Chevrolet Silverado 1500 and GMC Sierra 1500.  The Monroney label will include this credit and indicate that the vehicle was built without HD Radio. Chevrolet and GMC are updating all consumer and dealer facing materials as appropriate.
All orders of these affected vehicles entered in Order Workbench after June 23, 2021 will be built without U2L - HD Radio.  The affected vehicle order guides will be updated to reflect these changes and will be published on June 28, 2021. Each dealer has the responsibility to and must advise affected sold order customers immediately. In addition, dealers are strongly urged to counsel directly with all customers who purchase affected vehicles to ensure each customer understands its vehicle content.  This change to the availability of HD Radio is currently expected to be permanent.  A listing of affected trims is listed below and is subject to change by General Motors:
2021 CHEVROLET SILVERADO 1500
LT, RST, LT Trail Boss, LTZ, High Country
2021 GMC SIERRA 1500
SLE, SLT, Elevation, AT4, Denali
2022 CHEVROLET SILVERADO 2500/3500 HD
LT, LTZ, High Country
2022 GMC SIERRA 2500/3500 HD
SLE, SLT, AT4, Denali
MS3, thanks for the update.  I have a '22 HD on order and I'll be happy to take it without HD.  I have a '15 HD currently and I think I have HD but to be honest I'm not entirely sure!  HD is the feature that tells you the artist and name of the song if you are listening to FM radio correct?
As far as the change over to the '22s, it sounds like it's is still going to happen on July 12 at the Flint plant.  If you hear anything new at all about the 22s I would definitely be interested either via a new thread or a PM.  Excited to get the new truck and hope it's in August or September!
i think HD radio just allows the receiver to decompress and play the HD radio signals sent out by radio stations. some stations send out both analog and digital. an HD radio is needed to listen to the HD signals. the signals are a better sound quality
You don't realize how good HD radio is until you no longer have it.  Now if you stream or use XM primarily you probably won't miss it at all.
I was lucky enough to get the HD radio in my 2021 Sierra 3500.  I will say the sound quality is significantly better than Sirius/XM, but that's just my $.02 cents.
I have a 2021 SLE/Base; can’t seem to find an HD radio option in the head unit (stock radio). Does anyone know if this trim level just doesn’t come with HD radio?
HD radio wasn't available on the base trim, and was an option on the SLE trim level, SLT/AT4/Denali it was standard.
Thanks MS3DALE, wasn’t sure if I was
missing something within the options on the head. Since I didn’t order but rather purchased from inventory, options were limited. Not too concerned about it, used a HD radio on previous car to listen to one AM station on FM HD.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
