2020 silverado lt. I noticed the lights for the auto start/stop and the 120 outlet indicator light stay on, not at full brightness but at about 25%. Anyone know what could be causing this? It looks bright in the picture but it's actually dim.
Mine do the same thing, and I believe it's just the way it was designed, why, I don't know, but I don't believe it's indicative of a problem.  Just as an aside, when those functions are disabled, the faint glow is only noticeable at night.  During the day they look to be off, but in a dark setting you can see that they are glowing faintly.
Edited by Anacortes Army Guy
Both are turned on.  Press button to turn off.  Auto Start/Stop is defaulted to on from the factory.  The switch for the plugs is defaulted to off in my truck.  I assumed it was that way in all trucks.  I've anyways be able to see lights when they are on, but no glow when they are off.
6 hours ago, Htown_LTZ said:
The truck was turned off when I took the picture. Nothing should be on.
Maybe a stupid question, but did you open the drivers door after turning off the truck?
Power stays on for 10 minutes, or until the drivers door is opened.
Yeah, door was open. But like I said before, it's never done it until recently. None of those indicator lights should be on unless you press the switch.
Did you touch the on/off button after turning off the truck and turn on the accessories power by accident?
    Gspleezy
    Gspleezy
  • Who's Online   6 Members, 1 Anonymous, 688 Guests (See full list)
