bigger parts i am guessing.....
On 7/20/2021 at 6:44 AM, SILVER SLED said:
So why does the 6.2 weigh approx 100lbs more than a 5.3?
Larger displacement means more weight of metal parts
It’s the same basic block/engine though, the pistons are heavier due to the larger bore, but the stroke is the same, and I wouldn’t think the pistons are 100lbs heavier.  I didn’t think a 350 Chevy weighed more than a 305 Chevy for example.
Is it?  Iirc, the block has the engine displacement size as part of the casting.  The 6.2 litre blocks have a 6.2 sticking out on them.
Yes it is, in the fact you can take a 5.3 out and a 6.2 will bolt right in and can even use the same intake manifold and they both use the same exhaust manifolds. They have the same exterior dimensions, just wondering what makes a 6.2 100lbs heavier.  I can understand a standard 6.2 truck being heavier that a standard 5.3 truck, because I thought the 6.2 trucks come with a bigger rear diff. as std.
  • 3 weeks later...
Because of the smaller bore, the block and heads are not the same. I don't think gm would use the same amount of material needed to support 6.2l on an engine that only has 5.3l of displacement. There might be some cost reduction in manufacturing but.... I think using less aluminum would still net them more savings.
The 6.2 has a larger bore than the 5.3, which means the block is wider.  And, the rear is the same size in both trucks.  My 6.2 TB LT has the 3.23 rear.
The gear ratio is the same but non max-trailering 5.3 trucks have a 9.5” ring gear, and all the 6.2 trucks have the beefier 9.76”.
I was under the impression that on the LSX/LTX motors only the bore and stroke (rod length) and or crank & heads change to gain the larger cubic inch as they are all sleeved bores.  I have an older LT5 350ci and can go 415ci and have seen 427ci and 441ci with these changes same block.
Edited by WeGone
The blocks are the same size externally.
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
