Have a 2021 Silverado 2500HD, the owner's manual does not give info on front and rear differential gear oil capacity nor weight of oil needed. Anybody know?
This Amsoil site has always provided accurate information for both type and capacities.  Not sure if you have the gas or diesel but the below screen shot is for the gasser.  Both axles use 75W-90 and you can see the arrows that show how much.  The link to the site is farther down.  Hope this helps.
https://www.amsoil.com/lookup/auto-and-light-truck/2021/chevrolet-trucks/silverado-2500-hd-pickup/6-6l-8-cyl-engine-code-7-l8t-7/?volume=us-volume
Edited by 03 Cobra
There's a handy forum post that is used as a quick reference for info like this. I stuck it in my favorites since it's going to come in handy in the future :)
I just serviced the drive line on our 19 Hyundai Santa Fe AWD. Used Amsoil OE trans fluid and Severe Gear 75W-90.
The squeeze packs are nice to a point. On this car it was hard to use the squeeze pack on the transfer case due to a lack of room. The rear differential it was impossible to use it. Frame is so close there is barely enough room to remove fill plug.
I put a quart pump on the squeeze bag. Had to put the pump tube into the differential with long needle nose pliers.
Goter done though.
Goter done though.
Why didn't you attach a hose to the squeeze pack and then just squeeze it in?  That is what I did on the front axle of my truck.
Good point with the hose. I just grabbed the pump and it fit.
    • How did all that extra get added? AI bot!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
