I have one, and it is great for watching saturation level and regen status, among other things. I always try to let the truck finish its standard regens, even if I have to drive for a while longer.  I have not needed to run a manual regen.
Edited by Tomato
I have the data logging version.
After many years running stock LLY, LMM, LML and L5P. (LLY's were before DPF, so no regen; LMM's were DPF, but did not use exhaust fluid)
Now running an LM2.
This is the first time I've had an OBDII monitor. (way back when, I did add exhaust temp sensing to the LLY)
I have no intention of ever trying to have it initiate a regen.
I've always found, and the iDash confirms, that they will resume regen on the next drive, as soon as it gets the exhaust warm enough.
They will access many many many data items from the truck.
(and they are capable of adding extra sensors which might be necessary/desirable for modded vehicles)
There are lots of expansion options if desired.
I don't believe they are a need when running a stock truck.
For me they are a great way to satisfy curiosity, and to learn things about the truck.
I don't think I have changed anything in how I drive/use the truck.
I do find it interesting to see data beyond what GM chooses to display.
Seeing the 3.0L do passive regen when working hard is one of those things that was interesting to confirm.  Others have posted about the same thing with 6.6's.
If you aren't looking to spend a bunch just to satisfy your curiosity, you can get a much cheaper OBD II reader/scanner. My $45 Amazon ordered ANCEL AD410 let's me view DPF levels and regen status, plus a bunch of other data streams the vehicle presents via the OBD II port. It of course has its downsides, like not being very user friendly and doesn't save the screen where you left off, but it gets the job done. You won't be able to initiate a manual regen, but that really isn't something that you'll probably ever need anyways.
    tblt44
    tblt44
  • Who's Online   5 Members, 0 Anonymous, 822 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
