30 minutes ago, AirForceAngler said:
A product called Fluid Film is very popular with the Jeep crowd for prevent corrosion.
I don’t know from experience but I have read that fluid film doesn’t play well with the factory coating gm uses.
You can buy aerosol cans of the factory coating from the company that makes it, Daubert Chemical. https://www.daubertchemical.com/store/product-list/corrosion-prevention/nox-rust-x-121b
Fluid film works great on bare or painted steel. I used it to coat my plow in the off-season. It still looked new after 5 years. I've seen complaints about what it does to other surfaces such as rubber. I don't think I'd just go to town spraying my entire underside with it. But some people who run old plow trucks do coat everything. I also think it does not play nice with the noxrust coating though.
You can still use the Fluid Film (or cavity wax) in the rockers and fender lips. But I would stick to just touch-ups on the frame with the Daubert coating. I did it for years and the frames always looked pretty much like new.
thanks for that link, I need a can for touch up
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
    • I had an alternator fail that was shorted internally in such a direct fashion in addition to the larger gauge cables that it appeared like a VERY dead battery. Granted I think the car did power up, it definitely wouldn't start.   Rodent damage to wiring?
    • ... I don't think he could.
    • Using experience to justify bad advice is lazy and typical of someone incapable of articulating why their advice is prudent.    This immediately sets off the BS alert and the advice that followed certainly qualified.   Asking an idiot for help getting out of dumb situations because he is an expert... at getting himself into dumb situations.   Unless I've been living in an alternate universe - the first thing everyone does when getting into a sticky situation is shift to a higher gear 🤨.   Of course not, the torque multiplication, mechanical advantage and finer control typically afforded by the lower gear is far better suited for this scenario.   There ARE scenarios where a higher gear MIGHT be appropriate determined more by the drivers ability to control EXCESSIVE wheel spin versus applying torque to the ground.
    • I'm not sure I agree with "extreme" low speed, high torque sentiment here with regards to the prescribed use of low range. How about...whenever it's needed?   A 2.72:1 transfer case and whatever differential gears these Silverados have (3.42's, maybe?) aren't producing "extremely" low crawl speeds. Or insanely high torque multiplication. Even with the 1st gear in these newer transmissions. But it does provide mechanical advantage and potentially better control at slower speeds. And with extra weight or towing, I think it adds mechanical sympathy for the truck as well.   Plus, traction control and the other assists generally turn off when you shift into low range. Those aren't needed here, they'll work against you if you need wheel spin. In high range you'll need to figure out how to turn off the various modes those assists provide. Depending on the vehicle, those things don't all automatically turn off or turn completely off.   While I agree that a farmer might have some great practical experience, a recommendation to "always" using one gear isn't very informed advice. If the farmer had said WHY and could explain the physics behind his prescriptive "always" I'd definitely listen. The way he's described here makes it sounds like he could either be uninformed or is telling everyone what worked for him, not necessarily that there could be a more advantageous way about things.
