4 hours ago, M1ck3y said:
Interesting fact. A lot of people complain about the gearing being so low compared to competitors. But if you pick the correct (Taller tire) for your application you can reduce your 0-60 mph etc.
For ex. I put on slightly larger tires changing the axle ratio to 3.19 from 3.23. I know, small change. But enough that it now shift's just after 60mph and the 1/4 mile making better time. A lot of factors in this. But if you're traction limited a taller tire could be the way to go.
That is, if you use trucks for things they weren't intended for 😜
And taller tire's cover more ground. Less rpm for distance traveled so.. quicker at higher speeds
Correct me if I'm wrong, but to make this work wouldn't you want to same width tread?  Wouldn't going wider increase fiction with the road, thereby decreasing mpg via making the powertrain work harder to cover the same ground?  I've always wondered about this, but never got a solid answer.
On 10/15/2021 at 7:51 PM, tdc5152 said:
I’m in the market for a 14-18 Silverado or Sierra 1500. Ironically
So did you decide on anything yet?  I would be for the 2014 NHT.  Those 8-speeds are a pain.  The 6-speeds ills in the K2 are easily remedied.  One mod is to "flip the pill" to lower the temps which kill them, the other is to replace the torque converter pro-actively with an improved unit.  From 2017 on the transmission's computers are locked and cannot be tuned.
Yeah, width is definately one factor of many. End goal is to influence where you are in the powerband at a desired speed or distance to improve e.t Or speed.
Depending on the application you may be able to increase just width, or just height. Or quite possibly you might want to go with a smaller tire.
I was just mentioning how it worked in my application. I didn't have traction from a dig in 2wd with the oe tires. The extra 5 pounds per tire, friction from a larger contact patch, and slightly reduced gear ratio was just enough to give me traction without greatly affecting power to the ground. And put me in an rpm range that improves et because of a later shift.
But I'm actually waiting on some new wheels that are 2lbs lighter. Where that weight is on the wheel could have a big effect.
So all of this could potentially go out the window 😋
I'm sure Grumpy or someone will be along shortly to correct anything I may have stated incorrectly :idiot:
Thanks.  I'm not very knowledgeable about the engineering in all this.  I've often wondered how it all works, among other questions such as how it would affect towing, etc.
Don't worry about Grumpy.  Push any issue far enough with him and you'll have the same honor bestowed upon you that he bestowed upon me.  I'm on his ignore list.
Oh, by no means do I consider myself knowledgable on this topic. Just something I picked up.
Not worried about Grumpy. What I said was meant more as a jk.
Grumpy would actually do a great job of explaining this.
On 12/11/2021 at 1:52 PM, pokismoki said:
has anyone tried a comparision test between the Ford version of the GM 10 speed?  any difference in their shift tuning vs. GM's?
Just the tuning.
I've had many Raptor owners tell me they hate the 10-speed.  Apparently they thunk shifting into 4th and 7th on the Fords.  No issue to date with my Chevy.  I have 21,4xx miles on the odometer.  I did read an article once that they valving is different for GM and Ford 10-speeds.
The only 10-Speed I've seen out of the Fords is from single cabs and those guys love the 10-speed matched with the 5.0
I'm actually a little jealous cause those trucks perform stupid good.
So do ours
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 427 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
