 I do apologize if this isn't the correct place to ask this question. I'm in the market for a good OBDII scanner that would meet the typical DYI'er's needs. I've been reading about them online and, honestly, it can get a little overwhelming. I'd like to keep the cost under $200, any recommendations?
I use a Foxwell NT510 elite for GM and it has quite a lot of functions.  I use for my Silverado and Saturn.  I like it and it was  under $200.  I hope you find a scanner that works for you!!
I went cheap and got a Bluetooth one. It will read and give you the codes and also allow you to clear them. It is linked to my android phone using the app Torque Pro by Ian Hawkins. The Torque Pro I believe is a paid app but there is a free Torque Lite available as well. I bought it several years ago and it has served its purpose. The Torque Pro also allows you to monitor different functions as well.
Bafx Products - For Android Only - Wireless Bluetooth Obd2 Scanner Diagnostic Code Reader & Scan Tool - Scan, Reset & Clear Car Check Engine Light https://smile.amazon.com/dp/B005NLQAHS/ref=cm_sw_r_apan_glt_fabc_A2SX332AHWEHSJHQ0SDB?_encoding=UTF8&psc=1
Edited by mikeyk101
Depend on your needs. To best recommend a device, what are you looking to perform?
1. Something basic such as read and clear common code.
2. Able to perform more functions such as abs, brake bleed. Note alot of the basic reader does not have this function.
3. Access GM modules/program modules
All depends on what you want to achieve.  I have a $20 dollar code reader and it perform just as well as my $90 Bluedriver. Around $120, I can do things I wish I knew before purchasing the Bluedriver, it turns Bluedriver into a dust collector.
To do that, one will need a scanner that is more than $200.
I have an Autel MaxiSys - I like to work on cars.
I, also, have an Autosync with BTDiesel which unlocks the BCM and HMI for programming.
Also, a SuperChips F5 for unlocking the ECM.
If one just wants to read codes, and get resulting information, there are many.
If one wants to reprogram modules and dig in deeper, it's gonna cost a lot.
This is something that I have been thinking about. I'm the type of person that would like to have it and not need it, than to need it and not have it. I'd like to be able to read codes on multiple different vehicles. I'd also like to be able to access the GM modules that are in my truck.
- I've been looking at the Foxwell NT614
Thoughts?
That looks good for most DIY at home.
I have the vcx nano for GM. It already paid for itself after one use. I bought my truck used with only 1 set of key yet the truck shows 2 set of keys being active. I used it to deactivated all key/fob, cut my own keys and reprogram 3 set of key/fob. Just imagine how much the stealership would charge just to cut and program. I have also use it to program other modules thru ACDelco SPS services, an additional $40 access for 2 years.
For something quick/on the go/portable, I uses the $20 scanner along with torque pro. It's hook up to my spare phone which is linked to my truck via Android Auto. I can scan for codes on my truck's 8 inch screen.
I started a thread in the mod section if you're interested.
torque pro is ok, but if i found the pids  and other parameters where incorrect, and would give erroneous data.
 just get the HPtuners obd module, you can thank me later
Edited by pokismoki
It all depends on what you want.
i. If you want a cheap scanner
ii. Bluetooth scanner
iii. live data and more features that you want.
Then you want to check out these models, Blue Driver Bluetooth Professional OBDII, Scan Tool 426101 OBD Link MX Bluetooth, BAFX Products Bluetooth Diagnostic OBDII Reader. https://theeffectiveguide.com/best-obd2-scanner/best-obdii-bluetooth-scanner-reviews/bluedriver-obd2-reviews/
I hope you find that scanner that you want
Edited by Kevin N.
    Afennell19
    Afennell19
  • Who's Online   0 Members, 0 Anonymous, 876 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
