Hey guys, I'm needing a sanity check on an issue. In February 2021, a local, authorized BDS dealer installed a BDS 2.5" lift with BDS upper control arms and Fox coilovers (with DSC) on my 2020 Trail Boss. With this lift, they also put on Moto Metal Kraken 20x9 +0 with Mickey Thompson Baja Boss MT 35x12.50 R20. Eight months later (16k miles on lift) my front tires are shot. I'm very religious about tire rotation (every 5k-6k miles with dealer receipts as proof). The odd part is, there was no abnormal tire wear at first. It was only the last 3k-5k miles that my truck began feeling "different". I was hearing a random "pop" in the front end and upon closer inspection noticed an obvious positive camber. This is when I saw the tire wear. The installer's inspection revealed that both UCAs had loose nuts (one was actually missing)! They have fixed the suspension, but are insisting that I'm responsible for the cost of new tires.
Below is the timeline for this project:
  • Feb 2021 (< 10k miles on the truck) Installation of lift, tires, wheels, intake, exhaust, etc. Over $11k invested
  • March 2021 (1k miles after install) installer retorqued everything.
  • May 2021 (5k miles after initial retorque) another retorque and re-alignment. My steering wheel was off-center and the front end was "popping".
  • October 2021 (10k miles after last retorque, total of 16k miles on lift and tires) front end popping, positive camber and tire wear.
I'm intentionally not naming the shop until I get some feedback. But, they are insisting that they aren't at fault, saying "these things just happen". It seems obvious to me, but am I missing something? Shouldn't they be responsible for the cost of new front tires? Any feedback is greatly appreciated.
2 hours ago, stevejones said:
IMHO, it's all about what's written in your contract.  What does your paperwork say?
I have the initial estimate and final invoice. There is no statement of warranty in either.
Sounds like it should have been looked at when it started 'popping' in May .
Presumably shortly after the re-torque/align.
5000 miles driving with it loose/popping has taken out the tires.
imo, it would have been there issue to make the front end right in May.
(and I'd be pissed about having to take it back because it was left loose)
From the description, the tires were not worn unevenly at that point.
I don't think they can be blamed for driving it the next 5000 (from May-Oct) before getting looked at.
Is the shop torqueing everything while it's on a lift or sitting on the ground?  This can make a huge difference in suspension parts and alignment.
I have no visibility over their garage area.
Having been the mechanic, I kinda have to side with the shop on this but I can also slightly feel for the customer. Yes the tires did wear out rather quick in terms of mileage but if there was a known noise in the front end that is on the customer. The shop did what they were suppose to do at the time of the install and first repair.
My work might have given a small discount on two new tires but that would have been about it. Those tires I doubt came with any mileage warranty being that they are offroad tires. I used to see those kinds last 20-30k miles and be toast because they just get eaten on the pavement.
What should I have done, take it back to the shop? I did. They torqued the nuts at install, retorqued at 1k. I took it back to the shop at 6k because there was a problem and they retorqued again. Now at 16k the nuts are loose again? BDS claims, if the install was done correctly, the UCA nuts would not have backed off repeatedly. I have to agree.
I don't have an answer as to who's to blame. It is what it is. Modifying vehicles comes with a risk factor and you're going to have to fix it so take it to another shop. Buy new tires, align front end and hope for the best.
I'm just saying, you want to play, you got to pay.
Been there.
Been there.
On 10/31/2021 at 10:56 AM, Salty315 said:
Somewhere between this photo and 'mint' was months of clues including the "popping" noise. You didn't wake up one morning and go..."What beaver ate my tires last night". A lifted truck and you never see your tires for months??
And if you did "just notice it one day' then....yea                 You get to buy new tires on your dime.
I've taken it back to the shop every time I've noticed the popping noise. This photo was taken 9/25/21. Only 1 month prior to my previous pics. No beavers in my area.
Pretty truck. I don't say that about many T1's.
I have a tread depth gauge and use it. One important measurement is across the tread. It will show you a problem before your eyes will. Also take a paint marker and mark the caster and camber cams. A witness mark so at a glance you can see stuff moving. You have a great view of everything each time you fuel.
If you took it back with continued complaints, I'd say it's on them. I'd want to know why the nuts keep coming loose. That would be a bigger concern to me.
I agree, moving forward the concern is why the nuts are loosening. I should also clarify, the discussions between me and the shop have been very civil. We're just trying to work out the issue. This includes asking the kit manufacturer what's happening.
They're good guys and they do great work. I just wanted to get some feedback on whether or not expecting them to cover the tires was unreasonable.
    daveishi
    daveishi
  • Who's Online   1 Member, 0 Anonymous, 798 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
