Hey guys, I'm needing a sanity check on an issue. In February 2021, a local, authorized BDS dealer installed a BDS 2.5" lift with BDS upper control arms and Fox coilovers (with DSC) on my 2020 Trail Boss. With this lift, they also put on Moto Metal Kraken 20x9 +0 with Mickey Thompson Baja Boss MT 35x12.50 R20. Eight months later (16k miles on lift) my front tires are shot. I'm very religious about tire rotation (every 5k-6k miles with dealer receipts as proof). The odd part is, there was no abnormal tire wear at first. It was only the last 3k-5k miles that my truck began feeling "different". I was hearing a random "pop" in the front end and upon closer inspection noticed an obvious positive camber. This is when I saw the tire wear. The installer's inspection revealed that both UCAs had loose nuts (one was actually missing)! They have fixed the suspension, but are insisting that I'm responsible for the cost of new tires.
Below is the timeline for this project:
  • Feb 2021 (< 10k miles on the truck) Installation of lift, tires, wheels, intake, exhaust, etc. Over $11k invested
  • March 2021 (1k miles after install) installer retorqued everything.
  • May 2021 (5k miles after initial retorque) another retorque and re-alignment. My steering wheel was off-center and the front end was "popping".
  • October 2021 (10k miles after last retorque, total of 16k miles on lift and tires) front end popping, positive camber and tire wear.
I'm intentionally not naming the shop until I get some feedback. But, they are insisting that they aren't at fault, saying "these things just happen". It seems obvious to me, but am I missing something? Shouldn't they be responsible for the cost of new front tires? Any feedback is greatly appreciated.
2 hours ago, stevejones said:
IMHO, it's all about what's written in your contract.  What does your paperwork say?
I have the initial estimate and final invoice. There is no statement of warranty in either.
Sounds like it should have been looked at when it started 'popping' in May .
Presumably shortly after the re-torque/align.
5000 miles driving with it loose/popping has taken out the tires.
imo, it would have been there issue to make the front end right in May.
(and I'd be pissed about having to take it back because it was left loose)
From the description, the tires were not worn unevenly at that point.
I don't think they can be blamed for driving it the next 5000 (from May-Oct) before getting looked at.
Is the shop torqueing everything while it's on a lift or sitting on the ground?  This can make a huge difference in suspension parts and alignment.
I have no visibility over their garage area.
Having been the mechanic, I kinda have to side with the shop on this but I can also slightly feel for the customer. Yes the tires did wear out rather quick in terms of mileage but if there was a known noise in the front end that is on the customer. The shop did what they were suppose to do at the time of the install and first repair.
My work might have given a small discount on two new tires but that would have been about it. Those tires I doubt came with any mileage warranty being that they are offroad tires. I used to see those kinds last 20-30k miles and be toast because they just get eaten on the pavement.
What should I have done, take it back to the shop? I did. They torqued the nuts at install, retorqued at 1k. I took it back to the shop at 6k because there was a problem and they retorqued again. Now at 16k the nuts are loose again? BDS claims, if the install was done correctly, the UCA nuts would not have backed off repeatedly. I have to agree.
I don't have an answer as to who's to blame. It is what it is. Modifying vehicles comes with a risk factor and you're going to have to fix it so take it to another shop. Buy new tires, align front end and hope for the best.
I'm just saying, you want to play, you got to pay.
Been there.
Been there.
On 10/31/2021 at 10:56 AM, Salty315 said:
Somewhere between this photo and 'mint' was months of clues including the "popping" noise. You didn't wake up one morning and go..."What beaver ate my tires last night". A lifted truck and you never see your tires for months??
And if you did "just notice it one day' then....yea                 You get to buy new tires on your dime.
I've taken it back to the shop every time I've noticed the popping noise. This photo was taken 9/25/21. Only 1 month prior to my previous pics. No beavers in my area.
Pretty truck. I don't say that about many T1's.
I have a tread depth gauge and use it. One important measurement is across the tread. It will show you a problem before your eyes will. Also take a paint marker and mark the caster and camber cams. A witness mark so at a glance you can see stuff moving. You have a great view of everything each time you fuel.
If you took it back with continued complaints, I'd say it's on them. I'd want to know why the nuts keep coming loose. That would be a bigger concern to me.
I agree, moving forward the concern is why the nuts are loosening. I should also clarify, the discussions between me and the shop have been very civil. We're just trying to work out the issue. This includes asking the kit manufacturer what's happening.
They're good guys and they do great work. I just wanted to get some feedback on whether or not expecting them to cover the tires was unreasonable.
    • I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it? 80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
