3 hours ago, 16LT4 said:
Thread divergence: @Blainebug: out of curiousity, from your sig, are you an ACVW guy?
No, username has nothing to do with the Volkswagen Beetle.
Correct me if I am wrong but here are 4 lines I see running to my radiator and the condenser up front. 2019 Yukon with active aero shutters in the grille.  All 4 lines are the same quick disconnect style with the clip and plastic retainer.  Are all transmission related?  I didn't think the A/C lines used quick disconnects like these, but I'm also not sure where the engine oil cooler goes.  As far as I am aware there was an engine oil cooler.  I do not have a factory towing package, as in, no integrated trailer brake controller in the dashboard and no 2-speed transfer case (2wd, auto, 4-hi only.)
I'll have more cold weather data here shortly.
Its around -13F here this morning and I have to drive about 22 miles. I'm expecting it to get up to around 100°.
Temp was -12°F , around 15 minute warm up.
Trans temp was 37°F out of the driveway.
Drove a mile to Dennys. Trans now 60°F.
Shut truck off for 20 minutes.
Remote started it when I finished my eggs. Ate the rest of my grand slam and I was back in truck exactly 30 minutes later . Trans now 64°F.
Drove about 8 miles at 40 mph and stopped for gas. Trans now 118°F.
Cooled down to 114°F while idling 4-5 minutes.
Drove another 12 miles at 55mph and watched it drop to 88°F.
I think if I got on the interstate she would really cool down.
I got to think about this. I got at least 2 more months of below zero B.S.
I'm not really feeling crawling under it and re flipping it.
I'm also not feeling the 158 kit
I like it flipped when it's hot in the summer.
The 158' kit is worthwhile.  If you're like me you can sell your original setup for $40-$50 and be into the new thermostat for only around $20 😁
If someone is going to tap and drill the old housing for a plug I'd rather have a spare on hand just in case something cracks or gets damaged in the process rather than being out of a vehicle for god knows how long.  That's the value in the old units.
Edited by BlaineBug
44 minutes ago, BlaineBug said:
The 158' kit is worthwhile.  If you're like me you can sell your original setup for $40-$50 and be into the kew thermostat for only around $20 😁
My pill is flipped.  That was Free.
I don't drive a ton in the winter so I may just leave it
Driver side oil cooler?
Just walked out to our 19 Tahoe with aero, tow package (not max trailer).
Based or RPO we have aux trans and aux oil coolers.
Pass side:
Two larger diameter go to the radiator for aux oil cooling.
One small diameter is trans to condensor supply.
Driver side:
Condenser trans return
KC4 - oil cooling system
KNP - HD aux trans cool
Z82 - trailering equipment
NP0- single speed t-case
Edited by 14burrito
Pass side:
Driver side:
I don't have an integrated brake controller or two-speed transfer case so I doubt that qualifies me for the tow package (not sure what the difference is between tow package and max trailering package.)  However I did request a build sheet from General Motors and it is listed that I have "KC4 Engine Oil Cooling System" and "KNP Transmission Oil Cooler."  I also have "Z82 Trailering Equipment Package."  G80 rear locker with 3.08 gear ratio.
Edited by BlaineBug
As mentioned, neither do I. As well, two small diameter go to condensor. Double check your two larger diameter on the pass side, I bet they actually go to the radiator.
I believe 1 and 3 go to the condenser and 2 and 4 go to the radiator in my pictures.
PS, is your KNP really labeled "heavy duty auxiliary transmission cooler?" That is not what my build sheet says.
KNP - HD AUX TRANS. COOLING SYS
