55 minutes ago, vrizrak said:
Does anyone has ran a pill flip while standing still in the traffic when it's 100F outside? For longer than 15 20 minutes?
Yes,
7 minutes ago, Grumpy Bear said:
Yes,
What highest temp have you noticed? I really curios to see what temp are you getting in heavy stop and go traffic. I did mine past weekend. I was getting constant 185-190 regardless of the outside temperature. Now since pill flip initially while driving I was reading about 120. After 10 min idling temp jumped to 140 ish. Then after driving 40 min at 40 50 mph it lowered to 130. Then after idling for some time I was getting 170. Outside temp that Sunday was about 55 degrees.
Now today we at 17 degrees. And during my morning commute I was getting 111. Driving on the highway lowered temp significantly. After 20 min at 70 I was reading 90.
At this point I'm not sure if that what I want to see. Another question at temp I would need to adjust fluid level?
Highest ever temp I saw with pill flip was about 215 F sitting for an hour on a limited access highway behind an accident on a 95 F day. High enough the fans kicked on ever few minutes. Thus it cycled between about 190 F and 215 F.
Here's a chart I post every time this gets asked. It's a few years worth of data I collected and plotted.
The X axis is air temp in F and the Y axis is ATF fluid in F
My truck has only the radiator ATF cooler. Trucks with the second cooler in the A/C unit run a bit cooler.
My 'normal' highway summer temp is between 155 and 165 F. City a bit warmer BUT much cooler than with the TBV GM put on them. As long as the transmission fluid is over about 70 F all programing for shift and TC operation is satisfied. Over 104 F spark and fuel are on 'normal' maps. Cooler is a bit richer and a little less timing.
What you are seeing and so worried about it the way transmissions have been cooled since 1963. This TBV thing is something more recent in the entire history of transmissions and worries people silly than have never 'seen' what it was FOREVER. :)  Your transmission is fine.
3 hours ago, vrizrak said:
Thanks Marty. At what temp you suggest to check level?
With the pill flipped you don't have to worry about keeping the cooler and lines full. Just check at or above the normal hot operating temperature. For me that's around 160F or more. You still have to be at or over the cold check line however.
With the factory 192F unit over that.
With the "New" factory unit over 158 F
Both of those need the lines purged to get an accurate check.
Transmission temperature is usually running 140 +\- 5F. It did top out at 158 today in traffic. I have noticed my engine runs 5-10F cooler now. Are others seeing that too?
Does anybody know if the new tbv internals will swap out with the old tbv with the quick disconnect cooler lines? I have a 2014 Silverado and do not want to have to buy new cooler lines along with the new valve to make it work. Thanks.
Yes they will!  :) And will swap into the 8L and 10L TVB's as well. 😉
I don’t like any diesel after 2000, I don’t buy diesel anymore. I don’t like cylinder deactivation, I don’t buy them. If they tell me I can’t pick who works on it, I wouldn’t buy it.
I'm sure there is one and it may have been mentioned earlier in this thread but I don't think torque is as important on this. I followed nice and tight when I did mine and not ham fisted crank it on as tight as possible. Just snug it fully down and a tad more and you will be fine.
Found it. The official torque values were listed on page 4 of this thread
In the event that anyone was sitting on the edge of their seat in anticipation for the torque specs, you may now rest.
The bolt that holds the thermostat housing to the transmission case = 16 FOOT POUNDS (192 INCH POUNDS)
The bolt that holds the cooler lines to the thermostat housing = 106 INCH POUNDS (8.8 FOOT POUNDS)
https://www.gm-trucks.com/forums/topic/253735-im-sorry-but-it-is-kind-of-funny-gm-21-na-199/?do=findComment&comment=2554987
Edited by mikeyk101
Added info
  • Thanks 2
Or down snug and two squeaks.
:dunno:
:banghead:
  • Haha 1
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
