Hello Group,
Looking into re-gearing the Tahoe 5.3l 4x4 mom mobile from 3.08 to a 3.42 to get into a little better torque curve.
I have read through quite a bit of threads about gearing, sizes, cuts, 9.5 vs 9.6 etc, etc but one thing not mentioned was tuning.
I just got off the phone after chatting with ECGS and the closing statement from them was,
Quote
make sure you get it tuned afterwards...
I have re-geared Toyota's in the past and within the Toyota community, tuning after a re-gear is far and few discussed, mentioned or even thought of.
What is so special about the GM platform that the closing statement from East Coast was to make sure to get the TCM tuned after a re-gear?
I can understand the notion to ensure the tire size calibration is set properly...
On gearing topic,
Likely going to just run some AAM in the rear and look for a front diff assembly with the 3.42s already in place.
Anyone foresee any concerns swapping in a used assembly?
Anyone have any leads on some used diffs?
Thank You
As far as I know you just need handheld tuner to change the gearing. Dealership can do it too, getting them to do it is another matter.
But, maybe there's something more involved with 2017+ models?
Not tuning the computer can lead to many different things. The transmission can short shift or quick shift because it's seeing the mph far faster than it should. The heavy throttle mph settings will be incorrect, it might tag the rev limiter if it's too far out of whack.
The cluster MPH will be wrong, the cluster mileage won't report accurately, fuel mileage calculations and that will be wrong as well.
As he said above, a handheld tuner can do that change pretty easy. A shop doing the tune might be charging you a lot more money for basically the same thing.
I have to question the slight change from 3.08 to 3.42.
Not enough difference to justify the cost
If you do it at least go up to 3.73 or 4.10.
Stock tire size with no plans to go larger. *maybe one aspect ratio up*
AFM activation and fuel economy in general is much better in tow mode which is part of the reason for wanting to regear. Genuinely feel 3.08 is too high IMO.
Edited by 14burrito
3.08 is the most economical ratio in the GM line up.
It's just backwards from the way we think, if you have a 4.10 ratio and need better fuel mileage you would switch to a 3.42 or 3.73 gear ratio. If you have a 3.42 rear end ratio and need more towing power you would switch to a 4.10 ratio.
To a certain extent I can agree. But I also respectfully disagree as my fuel economy us upwards of 10% better in tow mode during daily use. Engine load. I see, both see via instant and result via tank, that tow mode puts me in a better part of my power band during driving. Sure my RPMs are higher as a result if a lower gear being chosen, but engine load plays a role as well. It appears that being at a slightly higher RPM reduces my engine load enough to get into V4 and stay in V4 much longer. Of course, driving habits and characteristics play a role and this may or may not be the case for you.
Edited by 14burrito
I've found that 35" tires, and 3.42 gears, once tuned to the appropriate tire size, increased my city mileage from a prior 10 MPG to around 12.3 MPG.
I don't get on the highway too often so I have no input on that.
Any change in gearing, or tire size should result in an ECU tune.
More info on gearing:
https://www.motortrend.com/how-to/1211or-why-change-gear-ratios/
Rule of thumb from the above link:
(new tire [size]/ old tire [size]) x original axle ratio = new axle ratio
Edited by MikeBMW
Thanks,
The speedo/odo being off is obvious and basic handhelds provide that option to recal.
The PT sides makes sense, but it caught me off guard that I never did anything prior to on my Toyotas and the shift profiles, general PT behavior remained pretty on point before/after.
    • Would you supercharge the 6.2L on a 2021 GMC Yukon Denali XL with ProCharger?.... 605HP is the stated number without going crazy - it's not the LT4 682HP package, but I'm tempted to install it... This vehicle was ... not... recalled on the engine swap - but I don't really know if that means ...don't do it... or do it;)    Maybe i should start a prediction market pool on it in case it blows up;)   Any thoughts appreciated - I already OWN the supercharger - stopped the installation when the recall was announced and now it's taking up space in storage until I can solve an electrical issue with the vehicle...  4th GMC suburban-equivalent truck - I like them a lot - when they don't a) discharge their batteries randomly, or b) throw a rod at highway speeds;)
    • We tested the sleep mode with an ammeter in series with the negative battery terminal - 30amp fused - so we do know the actual shutdown and non-shutdown current draws and timing of the shutdown sequence.  We just have no protocol information to determine what module is issuing the network keep alive.
    • TrueBlue...Even if you don't have that info stuff displayed, If Mr. Computer thinks there's something you should know about, it will pop up a warning message no matter what else is being displayed. I keep the speedometer displayed all the time, yet the brake pad message pops up anyway.
    • BTW, the 11.5amp draw is all the usual systems active - it's not a single draw - that's the "we're all awake" state of the vehicle - forinstance if the power steps are actuated, the draw will spike to 22amps for that operation.  when the battery is disconnected and then reconnected, the vehicle shuts down that one time only - and we see a 10-15minute progression down 11.5  10.5  9. 8 6. 5. 1.6... 500ma... and then off to sleep at 40 milliamp... as expected.  So we know it's a module that is simply refusing to allow the SDGM to proceed to the sleep state.  We do NOT think it is the telematics VIM module - since we already duplicated the problem with the "VIM bypass" solution installed (we reverted that since it also disables the gmc app - but it does not appear that the telematics system is the culprit).  We've replaced the rear heater control module, tested without the wireless charger, and the other modules on CAN Bus 5 - but still something is keeping us awake and removing X2 from SDGM allows sleep to proceed.  We cannot diagnose from OBD since OBD drops off at about the 9volt level in sleep mode and we can't communicate with the vehicle - also we can't trace the SDGM internal packets from the OBD side - we have Autel Ultra.   Any ideas on why disconnecting X2 would allow sleep to proceed appreciated.  This is no longer a repair situation - this vehicie is simply unusable in this condition and NOBODY at GMC Dealer can even understand what it is doing.  This is crazy.  We made these systems too complex and now we're paying the price.
    • Did this ever get solved?   I'm chasing 2021 Yukon Denali electrical issues - vehicle will not enter sleep mode - we can disconnect and reconnect the battery and it will sleep - but that's likely because we powered down whatever module doesn't correctly sleep.  once we start/accessory the vehicle and turn off, it will stay at 11.5 amp draw with something keeping the SDGM alive - it appears to be activity on the X2 segment, specifically CAN FD Bus 5 - but we don't know which device and we think we've already isolated all of the devices on that segment - so what keeps the BCM and/or the SDGM alive is unknown.   I don't yet have a packet trace from CAN 5 (and since this Global B we might not get much info from it) - but the vehicle has been down for 8 weeks and previously GMC Dealer was unable to resolve "kills battery" issues with this particular vehicle - so I'm at a loss - it seems to be beyond local repair capabilities - and the number of "telematics keeps vehicle from sleeping" posts indicates this whole architecture has major issues - I hate to say it, but we might have to install a battery cutoff switch on the front grill - one of those red boat switches - to turn off the vehicle.;)  Any pointers appreciated;)  I just bought a CAN FD interface and I'm planning to try Savvycan and Peak Can SW to triage this further.
