Searched through some other threads and didn't find anything that matches my symptoms.  It's an 05 Silverado 3500 DRW 4x4.  The only time I notice it is when going slow, as in walking speed, and either barely on the gas or at idle.  It sounds like a solid clunk with about every rotation of the tire.  I've jacked the truck up and ran it on jack stands, no noise.  I've turned the wheels by hand on jack stands, no noise.  I've removed the rear wheels to make sure there wasn't anything trapped.  Crawled under the truck and the u-joints seem fine, even greased them while I was under there.
Next on the list is to pull the hubs to see if maybe something in the parking brake has failed?  Any more suggestions?  It isn't spring related as I know there have been lots of issues around that.  It doesn't seem to get better or worse when I turn.  There is no vibration or noise going down the hwy.  You can't really feel the clunk unless you are really really paying attention and the surface is smooth.
Maybe chock the front wheels and using the engine to spin the rear wheels.  If you know it has an open diff and not a G80, you might also chock one rear wheel and then other other and see if it happens on one particular side (If you have a G80, this is dangerous, as when the relative speed difference makes the G80 lock, then the chocked wheel will suddenly really want to spin).
... and there's not much in the parking brakes to make a clunk, short of some part having come loose to roll around inside.
If you can't hear a loud clunk doing that test with the engine spinning the wheels, maybe try repeating it, and use a mechanics stethoscope (carefully) to listen to the backside of each hub, and to the diff housing, maybe you can hear something using it.
Did you clean the tires of all debris and check them for roundness? I often get what you describe and it's always a rock stuck in the tread, front or rear. Radial ply tires can fail with this symptom.
A clunk on each revolution indicates a wheel or axle related problem. The propeller shaft turns 4 times the speed of the wheels and final drive, so you can disregard that as a source.
Since this is a dually, I'd suspect the rear differential. After 16 years of towing and hauling it's not unusual for the rear end to go bad.
I already tried that and couldn't replicate the sound.
I have not checked for roundness but I would expect to feel something like that on the hwy.  I too am leery that it may be diff related.  What confuses me is that turning doesn't seem to change it and neither does throttle.
I did some more investigating today trying to figure this out.  It seems to come and go so I drove the truck on the road a while came home and jacked the axle off the ground and ran the truck.  I didn't hear the noise but let it keep running.  When I hear the clunk on the road it sounds like it's in sync with the revolution of the tires.  While the truck was idleing in gear on the jack stands suddenly I heard it... a loud THUNK.  After another 5 seconds or so it did it again.  Sounded like it was coming from the transfer case.  I cycled the transfer case through it's ranges, ran the truck in reverse, back forward, and even up through the gears and never heard the noise come back.  One thing I did notice is that if I got on the brake pretty hard after running it up to about 50 mph on the jack stands the tires would stop, then a loud thump from under the truck.  I am assuming the T-case is chain driven so it sounded and felt almost like there was a lot of slop in that chain.
  • 1 month later...
I spoke with my transmission rebuilder about this common issue. He explained that many GM/Chev truck customers describe a slight clunking noise that often occurs during acceleration from a stop or near complete stop. There is teflon grease that is coated on the splines of the driveshaft yoke that slips into the rear of the transmission. When the transmission fluid and filter are serviced, he recommends always removing the driveshaft with the yoke from the tail shaft of the transmission and re-coating the splines of the yoke with the teflon spline grease. He said GM doesn't offer this spline grease, but Ford offers it. He said that it is common for the teflon grease to dry out and dissipate over time and miles, causing a clunking noise that sounds as though it were coming from the rear differential. The teflon spline grease cushions the contact and connection between the driveshaft yoke splines and the transmission tailshaft splines.
This sounds like the same issue I had with my 2002 1500 Silverado.  GM fixed it with a new updated nickle plated slip yoke.  Took care of the clunk.  Seeing this is on a 3500 I would guess that it is a completely different yoke for sure, but might want to check and see if there was an updated one for yours as well.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
