Reserved AT4 refresh on night they were unveiled. Dealer called end of Jan for me to build. Went in and built on Feb4. Ordered AT4 refresh in titanium rush metallic, pricing came to 66k. Configuration was accepted but my truck has been sitting at an 0500 event code since it was ordered. This doesn’t make make me feel warm and fuzzy. Wondering if I should try another dealer or wait it out.
Can you forward link to check status of ordered truck.....would like to check my LTZ.  Thanks!
Just go to the gmc or chevy website, wherever you ordered it and initiate a chat with customer service and give them your order number.
I like that people are updating this thread with their results of what they ordered and the progress.
I'm anxious for the configurator to go live on the 3rd so I can see what I built and what packages I want, in case I wanted to make any changes to my order.
I had a tpw of 4-11 and now my tpw is gone and my status code disappeared too, thats what the chat said atleast, so they might be pushing things back or rearranging some things still.
It all seems so disorganized. Gm told me today my AT4 is still at 0500 but they used the term accepted but the dealer told me it’s in the system waiting to get picked up. My dealer screwed up though and told me they’ve had one AT 4 picked up. When I ordered mine I was told I was the first to order. Basically means they have the allocation to someone else.
Think they messed something up. Submitted order should be 1100.
GM Order Tracking - Event Codes & Definitions | GM Authority
https://www.corvetteforum.com/forums/c8-general-discussion/4318945-event-code-500-a.html#post1600134014
I ordered a refreshed AT4 1/14. My order had an event code 1100 for roughly 6 weeks. GM acceptedd my order yesterday 3/1 & moved to event code 2000.
Refreshed LT Trail Boss 3.0 duramax. Pearl white. Ordered on January 7th and accepted on January 31st. I check status on February 23rd and I’m told my order has been submitted but not accepted. Just checked again today and it still says it hasn’t been accepted. Anyone else have this happen or have any idea why?
Edited by Frey23
It means your dealer is waiting for allocation for your truck. They only get so many per week and every week its a different mix of trim and option constraints. They might get allocation for a lt trail boss but only with the 5.3l and so they put someone elses order into the system that week.
Does an order number ever change? I added the technology package and my updated order has a different number. It’s also now listed as retail sold vs stock. I’m thinking something happened and my order got redone and I was checking the old number.
I'm guessing they originally messed up and put your original order in as stock and reentered it as retail sold to fix it (which is what it should be).
Edited by UCF w00t
This would make sense as to why the other number was showing as an 0500 event code.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 252 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
